On One Scandal
On One Scandal
8 Users
So I’m looking at a on one scandal 29er
Looking at the size guide I’m in between a small & medium. I spoke to Planet X on a web chat and they basically said my height 5ft 6 would suite both the small or the medium and explained that a medium would be more comfortable on longer rides because of the raised handlebar height and a more stretched position meaning a more upright position. A small frame would be more compact with lower handlebars etc but would be more agile etc etc.
I’m abit unsure what to do really a small frame is 15 and medium is 16.5 is there anyone one who has one of these bikes who is similar height who could shed some light on this for me.
Thanks
Tom
Posted : 23/12/2022 8:05 am
Wading through this giant 31 page thread will probably tell everything you need to know
https://singletrackmag.com/forum/topic/the-new-alliminium-scandal-29er-from-on-one-planet-x/
Posted : 23/12/2022 8:33 am
I’m 5 7 and am happy with medium jack flash and whippet.
With my jack flash I’m right on the seatpost insertion limit, even with my short legs.
I’d ask them how much insertion you have at your given seat height.
Posted : 23/12/2022 8:36 am
Thanks I’ll have a read see what I can find. Yeah that’s a good point I don’t wanna be running my seat tube at a max height if I was to get a small for instance. I’ll ask the question.
Posted : 23/12/2022 8:42 am
I think it depends how long your legs are and how much drop you want to fit in. At 5’9 I’d probably go medium because the seat tube in the next size up is quite long at 460mm.
The medium has a reach of 437mm which I’d think would probably be ok for you - and the seat tube is fairly short at 420mm. I’d just check with them how much seatpost insertion there is and then workout how much drop you can fit in.
The Oneup v2 dropper has some height adjustability and the biggest drop in the smallest space so I’d look at one of those.
Posted : 23/12/2022 8:48 am
I have little legs think there about 28/29” long 😂
Posted : 23/12/2022 8:58 am
If I engage brain I can say that I bought a medium off eBay that in fact turned out to be small. I couldn’t figure out why my minimum insertion was an inch above the top.
To prove to the seller he was wrong I took pictures.
The measurement is from the centre of the BB
Posted : 23/12/2022 9:11 am
I'm 5ft5 with short legs and ride a Small Whippet. A medium would be too tall for me.
Posted : 23/12/2022 9:19 am
Bear in mind - the Scandal frame uses a kinked seat tube - the effective seat tube angle is 'synthesised' and not a true seat tube (post!) angle.
This means that on the same frame size - if your at the smaller end, with a lower seat - you have a steeper seat tube, and a shorter top tube length, or if you are taller, you will have a slacker 'real' seat tube angle and a longer top tube.
I am 5ft10 with short legs and had a medium. Think about what dropper post length you want to run, and compare the C-T seat tube measurement to your current bikes.
Posted : 23/12/2022 10:47 am
I'd definitely say the medium.
I have similar stumpy legs to you but a longer torso, and I'd only consider the large for myself.
Good deal on those at the moment.
Posted : 23/12/2022 11:18 am
It’s strange as when I spoke to them this morning regarding seat post they said small has a 340mm insertion and medium is 380mm. They also said stick with a small for a safe bet because of my height and leg length. It’s a difficult decision
Posted : 23/12/2022 12:14 pm
5'7" here. Centre BB- top of saddle 706mm. 70mm stem. I ride a Medium. I put a 125mm dropper in, but actually have space for 150mm.
The stack on small and medium are both listed as 609mm on the website, so that shouldn't be a factor.
Its a great frame, though on the GX build the wheels and fork are poor, and sram 29mm axles in a BSA bb mean the bb bearings last seconds to minutes 😉
Posted : 23/12/2022 12:26 pm
Can you try a couple of friends' bikes with comparable reach figures? See which feels best.
The medium Scandal is about where most brands current small models have ended up though.
Posted : 23/12/2022 12:48 pm
Yeah I must admit looking at the size of others the on one scandal medium seems to be similar to other manufacturers small. I have a giant hybrid that’s a small and that’s at 16.5 frame and I find that comfortable
Posted : 23/12/2022 1:29 pm
I honestly think the medium is a safe bet for your dimensions, you could always go a bit shorter than the stock 50mm stem if needed.
Posted : 23/12/2022 2:57 pm
Yeah I think I’m going to try a medium. I did read that you can return them if there not the right size. Obviously they have to be seen as new and no damaged but it’s good to know it’s doable if need be.
Posted : 23/12/2022 3:07 pm
