On one fatty bb dyi...
Ā  You don't need to be an 'investor' to invest in Singletrack: 6 days left: 95% of target - Find out more
[Closed] On one fatty bb dying
4 Users
My second hand fatty is making sounds like there's broken marbles and sand in the bb shel instead of nice bearings. It's an sram x5 chainset and I don't know what bb.
I'm new to fatties, what are my options ref bb?
I'm not that fussed with the sram shifters either and the cassette/ chain is worn as well.
What are my 2x10 options ref chucking shimano shifters/ cassette/ poss new middle chainring on I guess I can reuse the cranks with a new bb? Any hollowtech 2 bbs/ cranks available? It's a100mm bb I think?
Posted : 02/05/2016 9:45 am
SRAM GXP bottom bracket, ie shite unfortunately, and incompatible with everyone else's stuff. I had a google and Gusset do a compatible one now, that's a win...
http://www.tritoncycles.co.uk/bmx-parts-c7/bottom-brackets-c101/gusset-external-sram-gxp-bottom-bracket-p12677/s35578?utm_source=google&utm_medium=cpc&utm_term=gusset-external-sram-gxp-bottom-bracket-bbguxs2k&utm_campaign=product%2Blisting%2Bads&gclid=CIH77IOSu8wCFcWVGwodBekLRg
I haven't used this exact product but I use their Shimano-compatible one and it's good. Way better than SRAM's junk. Pretty sure this will work in your bike.
Posted : 02/05/2016 10:07 am
North wind. Good man. Will try these.
Did you know (from tweets cycles website) that "sram have now achieved total drivetrain nirvana...."
What a load of marketing boll£&s...!
I guess I can use shimano 10 sp on the back end/ shifters with a new sram chain with no probs?
Posted : 02/05/2016 10:27 am
North wind. Those bb cups only fit 68/73 width due to the internal sleeve. I guess I just bin the internal sleeve then and it'll be fine in a 100mm shell?
Posted : 02/05/2016 10:31 am
That's what I do- you might find the SRAM one fits too though. To be fair, not everyone thinks this is a good idea. If you find there's a lot of debris/water in the BB shell then maybe it's a less good idea since the inner tube could be protecting the bearings. Equally I've sometimes found water trapped inside the inner tube, which has got to be counterproductive. I think it's much of a muchness personally.
All said, I'd rather have a Gusset BB and no tube, than a SRAM BB and a tube.
As far as I know... if you want to keep it OEM and with a tube and all then probably it's either SRAM again, or maybe Hope will have a fatsno option but it'll be pricey.
For all the other stuff... SRAM and Shimano chains are totally compatible as long as it's the same speed. I like KMC personally, ymmv... Maybe you can get a decent deal on a bundle?
Posted : 02/05/2016 10:45 am
Im still on the original GPX BB on my Fatty, 6200 miles and 1.5 years latter.
Its the same with anything, if you look after it, it should last.
I do have full mudguards though, so very little water/mud gets blasted into it from the tyres.
When you put the new one on, get some waterproof grease and pack it in to help keep the crap out.
Posted : 02/05/2016 12:23 pm
Sram x5 GXP bottom bracket is pretty junky, I've had mine replaced twice in 6 months, they made me pay for it first time making out like it was my fault as I had installed it, I'm still bitter about that.
Posted : 02/05/2016 12:36 pm
The previous owner of my fatty rode the coastline a bit I think. I'll take a gamble on the cut'n shut option and can report back if it works/ doesn't work.
Burko
Posted : 02/05/2016 7:58 pm
