On bike storage and...
On bike storage and bike transport
4 Users
1 Reactions
I transport my gravel bikes on a towbar rack. I normally remove my small daily use saddlebag, water bottles etc, I guess for security and maybe windage, given bike is side on to up to 70 mph wind load.
just got a lovely new Tailfin toptube bag, a 1.1l version, which can be bolt on or strap fitted. My logic says use the straps so I can remove it for transport, but the bolt on option is a bit neater. Will a 3 hr drive at motorway speeds result in a bag that no longer sits upright, or at worse loosened the bolt mounts into my carbon frame ?
I may be overthinking this..
Posted : 27/04/2025 7:18 am
Kept my bolted on TT bag on the bike (on towbar rack) when travelling 5 hours each way to lakes last weekend and there was no issue with it. The tailfin gear is very robust and weatherproof.
Posted : 27/04/2025 7:22 am
It might depend on the vehicle. I've had bags attached to bikes on the rack behind my van without issue but the aerodynamics would be different if it was a low-slung sports car. A 1.1 litre top tube bag isn't that big though, so I imagine it would be just fine.
Posted : 27/04/2025 8:04 am
Thanks, car is pretty low/aero - BMW i4, so I can imagine there could be a heap of slippery air hitting that area of the bike. Might bolt it on but take all the contents out ?
Posted : 27/04/2025 9:06 am
FWIW, I've driven many thousands of miles with my bike on a tow bar mounted rack and never once felt like I needed to remove the saddle bag (and it's never moved). Sometimes I also had my frame bag on as well. Again, it's never been a problem...
Posted : 27/04/2025 5:57 pm
iainc reacted
thanks for the input, will bolt it on methinks
Posted : 28/04/2025 7:01 am
