"Old" vs New Brakes
[Closed] "Old" vs New Brakes
4 Users
I'm a late 90's/early 00's mountain biker that's just getting back in to the game. The last bike I had was an Orange hardtail and in 2004ish I gave it a pair of the latest and greatest Hope Mono M4s front and rear. They got 6 months use then they got parked for over a decade. For the last year or so I've been back on that bike while I decide if I want to invest in a new bike and I've decided I do.
Recommissioning my old hardtail meant I had to fully strip and rebuilt my Mono M4s and since giving them fresh seals, pistons etc etc they've been working perfectly, if a little over powered for the bike.
My question is - if I put together a new full sus, ~140mm build that's got something like, say, SRAM Guide R's on it, am I gaining anything over my old but perfectly functional M4s? I can still buy pads and parts for them, and I know they might be a little heavier and a little less adjustable, but ultimately it's a hydraulic disc brake and it seems to be doing the job.
Can anyone give me a really good reason to bin them and go for something brand spanking?
Cheers.
Posted : 06/08/2018 1:14 pm
Not much, tbh. Brakes have got lighter and some have got more reliable, and in general they're better at balancing power and feel which used to be more or less a choice you made. But, frinstance, I've never used a modern brake that I like as much as my old Formula The Ones that I have on everything. Brakes aren't complicated, really, so they got really good really quick.
Posted : 06/08/2018 1:19 pm
It depends what brakes you are comparing them to I suppose. I’ve not used Hope M4’s - my only experiences of Hope brakes are C2’s and the early mono mini.
I’m now on guide r’s and they are a lot better. However not long ago I had some slightly older Deore (m535 I think) and they were significantly down on power compared to the Guides, and I suspect the mono mini had more power back in the day.
If the M4 feels overpowered already and you are going to buy a frame and components separately then you may as well try your hopes and see how they go.
If you’re buying a decent spec 140mm fs bike it’ll probably come with good brakes and there’s probably not a lot to be gained putting the hope on. I like my match maker clamp on the fs bike - the guide and the gx shifter run off one bar clamp - and Shimano can do the same with ispec (although there seem to be a lot of ispec variations that aren’t compatible with each other).
Posted : 06/08/2018 2:13 pm
FWIW I have- and still run- a set of Mono M4's purchaced 2003 ish (possibly before- if not at the point they came out, not sure when they were released)- I recently sent the rear one off to Hope for a service and three days later I had a brake that is IDENTICAL in function to the the new E4 on the front of the bike. Genuinely worth considering doing imo.
Posted : 06/08/2018 2:53 pm
Thanks for all your input. I think it's probably worth taking a punt on them for now and maybe trying some newer brakes on other bikes as and when I get the chance. The latest Guide Rs are only about 100g lighter at each end and I could make up that difference elsewhere so I'd potentially rather keep the £400 in my pocket.
Posted : 06/08/2018 4:14 pm
