Hi,
I have a old SID XC rear shock in my Giant Nrs bike and I need seals but there aren´t replacement parts?
Could be suitable parts of the service kits of Ario, Bar or MC3 shocks (can rod wiper, can u-cup seal, etc)?
These shocks are 25 mm (1 ") diameter body too.
What are the dimensions of the shock? I have a165x38mm vanilla float going cheap.
I serviced my old SID XC and it was still a poor shock.
I bought a looked after, just TFTuned serviced Fox RP23 and it was night and day.
The fox cost £120 and I ran it for 4 years...
I wouldn't waste money on the sid - you can get cheap second hand shocks to suit on here and they'll be much better.
I think the issue with the NRS frame was that they need a specific type of rear shock that supported the frame in the 'sweet spot' for the suspension when sagged by rider weight.
So you need something with either a separate positive and negative air chambers. Fox did make a specific shock for the frame and Giant had their own brand one too.
They did ideally need one with a dual chamber design to allow it to sit just topped out normally but you could get near enough the same effect with a single chamber design with some decent damping.
I had an NRS without a dual chamber shock FWIW.
