Old school fork cho...
Old school fork choice?
5 Users
4 Reactions
I'm building a nukeproof cub scout up for my kid who is 55kg and not massively gnarly.
I have a choice between these two forks to fit to the frame.
RS Rev XX world cup dual air 140mm.
Vs
Dtswiss XMM140 twinshot. 140mm
Both with straight steerer & 15mm bolt thru.
Frame is specced to 120mm fork.
Which would you choose?
Posted : 11/05/2024 4:10 pm
I had both a Rev (not World Cup though) and DT XMM back around 2010/14. The DT was better in every way including build quality, plushness and general performance. Best pre modern Pike fork I had.
Posted : 11/05/2024 4:28 pm
DT probably a better fork. But the rev can probably be shortened to 120mm (with spacers iirc as it's dual air) and with the dual air you've more tuning options.
Posted : 11/05/2024 4:48 pm
Which can you get spares for? That would be my first consideration.
Posted : 11/05/2024 5:15 pm
thols2, zerocool, zerocool and 1 people reacted
This.
Posted : 11/05/2024 5:59 pm
Not a lot (if anything) for the twin shot, use that until I dies I guess.
Posted : 11/05/2024 8:04 pm
Pretty sure Pace still service the DT?
Posted : 11/05/2024 9:11 pm
Not the twin shot bit, tf tuned replaced the abs under warranty and it's been fine since but no one is currently doing it.
Posted : 11/05/2024 11:15 pm
