old nad amp
[Closed] old nad amp
8 Users
i got a nad 3220pe amp and just had it on medium volume and it overheated. 1st time its happened. Is it a major problem
Posted : 19/05/2010 7:41 pm
I've an old AMP as well, the bearings are beyond repair now so it's hanging on the shed wall. 🙁
Posted : 20/05/2010 1:03 am
LOL....
Posted : 20/05/2010 2:14 am
could be something simple like dust build up internally. I'd take the cover off and blow it out.
Posted : 20/05/2010 2:21 am
Indestructable,my flatmate peed in MINE and it still worked(stank a bit mind)Blow dust off as they run hot.
Posted : 20/05/2010 4:19 am
I took cover off and dusted it. found 3 blown fuses, if i replace these with time delay fuses. Would it work
Posted : 20/05/2010 1:07 pm
there's probably a good reason they aren't time delay fuses. They are designed to allow small spikes in current of the type not generally caused by gradual overheating
Posted : 20/05/2010 1:08 pm
do i just replace them with quick blow fuses. cause i got alot of heat from the capacitors last nite at a medium volume. just generates a lot of static noise from both channels.
Posted : 20/05/2010 1:44 pm
find the cause of the problem before you replace fuses, they are there to protect other stuff which you'll just cook if you keep blowing fuses
check you haven't got a dead short or some leakage in your speakers/cables
Posted : 20/05/2010 1:53 pm
there was a bit of burning smell from the capacitors - could they be gone. its a nice amp and dont want to get rid of it. but i dont want to spend much fixing it
Posted : 20/05/2010 1:55 pm
you've gone beyond my knowledge now, try hitting it with a hammer
Posted : 20/05/2010 2:00 pm
Depending on age, there was a spate of bad capacitors a few years ago. Lots of motherboards fell victim to it. There's a good article on Wikipedia somewhere about it.
[url= http://en.wikipedia.org/wiki/Capacitor_plague ]Wikipedia link here[/url]
Posted : 20/05/2010 2:01 pm
there is sound there. but a lot of hissing and static. the capacitors are 4700 uf's, i'm not too sure where the problem is. i could replace the capacitors and fuses. but that might not solve it
Posted : 20/05/2010 2:10 pm
Listen to some early 80's industrial music on it then you won't notice the difference.
Posted : 20/05/2010 3:24 pm
Electrolytic capacitors will die with age, so they could well be busted.
The fuses will be blown for a reason, so just replacing them won't help.
Posted : 20/05/2010 3:34 pm
I can get the capacitors and the fuses from maplin or rs components. But I dont know if that will solve the problem
Posted : 20/05/2010 3:39 pm
