Old Disc Brakes - n...
[Closed] Old Disc Brakes - new rotors worth it or best to buy new brakes
7 Users
 jlc
Got an old pair of xt disc brakes over 10 years old. Performance isn't great after a bleed and cleaning the rotors. Think the rotors could be contaminated as squeal like mad. It is worth buying some new rotors or is it likely the brakes / deals have had it being 10 years old? Haven't had loads of use over the last 10 years due to road riding.
Posted : 09/08/2020 11:53 am
Assuming that the seals aren't leaking, they should be fine. If the rotors aren't badly worn, I would try cleaning them thoroughly with hot soapy water then lightly sanding them. Then fit new pads and bed in.
Posted : 09/08/2020 11:59 am
 jlc
Tried the light sanding and disc brake cleaner but started squealing again on the 2nd ride and getting worse.
Posted : 09/08/2020 12:01 pm
Leaking seals. Brakes are scrap
Posted : 09/08/2020 12:05 pm
Shimano rotors new are 1.8mm thick, Shimano advise to replace them at 1.5mm, might be worth checking.
A degrease of the rotors with IPA / disc cleaner will sort any contamination issues, add in some new pads too, but at 10 years old the caliper seals might be the culprit.
Posted : 09/08/2020 12:15 pm
It does sound like leaking caliper seals. If the levers and hoses are still in good nick, maybe just replace the calipers.
Posted : 09/08/2020 12:48 pm
Pads. Far more likely to be goosed than the rotors, worth trying before binning.
Posted : 09/08/2020 1:39 pm
There is little point cleaning rotors if you don't replace the pads at the same time. Most of the contamination from the rotors quickly gets absorbed by the pads.
Posted : 10/08/2020 8:09 am
New brakes.
10 years on a set of shimano's must be a record. Are you sure they work at all 😆 Go on, treat yourself, you deserve new brakes once in ten years.
Posted : 10/08/2020 10:48 am
