Ohlins RXF 36 Saint...
[Closed] Ohlins RXF 36 Saint brakes problem...
3 Users
Hello, i Have this fork with the Shimano Saint brakes (203mm disc front) but the PM6 adapter doesn't work for me. I have this adapter:
What is the problem?. Do I need another adapter?.
Thanks.
Posted : 26/11/2017 7:55 pm
You need a Hope H mount as IIRC the RXF 36 has a 180mm post mount fitting as standard.
Posted : 26/11/2017 7:57 pm
Shimano 180 adaptor fitted to ours
Posted : 26/11/2017 8:03 pm
Thanks for your answers.
Have any image or link about these adapters?.
I want for front disc.
Posted : 26/11/2017 8:08 pm
Is this, right?: [b]180mm Rotor - PM160 Fork[/b]
Thanks!.
Posted : 26/11/2017 8:43 pm
It is with the Ohlins as it's set up for a 180 rotor in that you wouldn't need a mount for it so you need the 180 adaptor to make it fit a 203 rotor
Posted : 26/11/2017 8:47 pm
Perfect!.
Of the 2 adapters that CRC have, I need buy the [b]180mm Rotor - PM160 Fork[/b], right?.
Thanks.
Posted : 26/11/2017 8:51 pm
That's the one. The bottom one in the picture. Just make sure you put the longer bolt through the wider part of the adaptor
Posted : 26/11/2017 8:54 pm
Okey, perfect!.
Thanks again! :).
Posted : 26/11/2017 8:56 pm
