Odd because I've not had this before and google is letting me down on this, so I'm turning to the collective singletrack wisdom....
Went to do a bleed on a 1st gen reverb stealth, did the usual process of: raise front end of bike; raise seatpost to full extension; rotate mount round so screw was at the high point; wind the speed out to slow; bleed screw out of remote and pop a 1/3rd filled syringe in there; same at the post end with 2/3rds full then the in-out/push-pull of bleeding the system and took everything back out. Nothing unusual so far, but when I go to press the remote it is absolutely solid now. Maybe 1mm of movement.
I've retried the process a couple of times now and done the remote bleed too, but nothings made a difference and it's fairly rapidly making me want to throw the damn thing out the window - so has anybody hit this before? How am I screwing this up ?
Empty syringe at the post.2/3,s at the remote then bleed.
Follow this. 😉
[url=
Wouldn't make any difference as it's the same logic. And I've just tried that and sure enough, it didn't.
I would place money on a kink in the hose inside the frame
This happened to me before and it was indeed a kink in the hose inside the frame. It's a bugger because the hose now has a permanent slightly bent bit which makes it not quite as smooth as it should be.
Absolutely bang on, it's a kink.
Downside is that the bleed hasn't fixed the slight suspension the post currently is giving me, so it's a warranty job anyway as the air & oil must be mixing.
Thank you both though.
