Does anyone know if the nukeproof Generator front hub can be adapted to 20mm?
I thought it could, but I can only find stuff saying 15mm or QR.
This review says you can:
https://www.bikeradar.com/reviews/components/wheels/wheel-sets/nukeproof-generator-am-mountain-bike-wheelset-review/
This webpage says you can’t:
https://www.chainreactioncycles.com/nukeproof-generator-20mm-end-caps/rp-prod63941
That is both helpful and unhelpful! Thank you!
Maybe not directly but have a look at the bearings, either they have 20mm inner diameter or could be swapped for ones that do, I essentially did the same operation to convert my Hope XC to 15mm (with an additional machined spacer and end caps). Always worth checking. If you can get the correct size bearings speak to Kayla1, she made up the rest of my conversion kit.
my nukeproof generator front hub is 20mm and i`ve the 15mm adaptors in a box somewhere.
they may have changed the design now though as its a good few years old.
Yes, my old Mega had 20mm axel Marzocchi 55's on it.
