Nukeproof ARD inser...
[Closed] Nukeproof ARD inserts - blocking up
1 Users
Hi all.
Anyone using these and having problems with the valves being blocked by the insert?
I suspect that either the little grooves that allow air to get in/out are filling with sealant OR the valve is being turned slightly sideways during use of a pump/tightening of valve inserts though in theory everything should still work in that scenario. PS It’s not the valve cores. Still blocked with them out !
(but can’t prove until I take everything apart - not keen to do that ... as away from home right now so not got all the stuff I’d ideally like for refitting)
Anyone else seen this?
Posted : 22/10/2019 10:45 am
