Now we've done fron...
[Closed] Now we've done front lights- Whats your choice of rear lights
56 Users
Plenty of threads over the years about the best, the brightest, the most rugged or expensive front lights be that bars or lid, but what about on the rear.
I've had a number over the years, Cateye,Smart and currently a Raleigh, this last one being quite good with a steady lamp as well as 2 flashes followed by a longer brighter flash, and of course a constant. Part of a set i got ages ago - RX1.0 65 lumen rear i think.
One of the problems trying to pick a replacement is they all advertise as being the brightest. But being bright is one thing, being noticeable quite another.
So what does the group favor these days ?
Posted : 23/12/2021 8:12 am
Mrs_oab and I have a Silva rear light each. They've done about 5 years and one is finally playing up. Pretty basic, but really bright and visible 180*. One of those products that is ace quality long term without having any fuss or showiness.
Middle_oab just bought some Bontrager Flare lights. The rear is a miracle of size and power, complete with, err, flashy flash modes. Seems really well made too.
Other than that there is a pile of cheap Halfords or Aldi lights that also get used, although none are anything beyond 'they work'.
Posted : 23/12/2021 8:23 am
For the road; garmin varia. Amazing light and it has had a noticeable change in the way drivers pass me.
Off road, Moon Comet or Gemini for me.
Posted : 23/12/2021 8:24 am
If you need to be seen from space, Hope District.
If that’s not a requirement, Moon Nebula.
Posted : 23/12/2021 8:26 am
Aldi specials here, the long lozenge shaped ones, plenty bright run for hours and hours, mine are about 4years old, always run one of the smaller ones on flash as a redundancy too.
Posted : 23/12/2021 8:31 am
Garmin TraceR
It's got a flashing mode that goes "dim - FLASH - dim - FLASH" so is never actually off.
It goes very bright in mode 1, so good for daylight road rides and still has 6 hrs battery life when flashing.
Modes 2 and 3 are much longer life and when in steady mode more useful for night rides especially in a group.
Also well made and good service. Mine has the rubber seal that covers the switch and charging port start to show signs of the "tab" you use to access the charge port tearing after 2 or 3 years use - email to Exposure and one arrived the next day in the post for free.
 kilo
The traceR is very, very good unless you want to fix it to a bag in which case the mount is of no use whatsoever.
Posted : 23/12/2021 8:35 am
 wbo
What's the general opinion on whether, for rear lights, you'd rather have one good or multiple cheap? I've gone for the latter
Posted : 23/12/2021 8:36 am
Exposure TraceR 👍🏻👍🏻👍🏻👍🏻👍🏻👍🏻👍🏻👍🏻
Multiple cheap implies that they will fail at some point, you don't want a rear light to fail. Buy the bog standard Exposure TraceR.
£32 @ https://www.sigmasports.com/item/Exposure-Lights/TraceR-Daybright-Rear-Light/GDDM
Posted : 23/12/2021 8:38 am
 nbt
My Cateye Holy Hand Grenade (TL-LD1100) is still going strong despite being maybe 20 years old (I bought it from Dan Barham when he moved to Canada and it was not new then)
Moon lights are good - we have an Arcturus Pro for the tandem that also has a saddle rail mount for Mrs NBT's MTB, we only went for that one as
a) it was on offer at half price
and
b) it included the saddle rail mount, which is really useful if you run a dropper post on a small ike - if you mount low on the non-dopping part of the post it gets obscured by the wheels / mudguards
Posted : 23/12/2021 8:40 am
Exposure TraceR Reakt under the saddle, Knog lil Cobber on the seatpost and a Knog Mini Chippy on the frame as a backup light. Exposure Micro Red Eye on the lid.
The wee exposure one that plugs into the rear of helmet light, and a lezyne zecto that I got with a mag subscription over 5 years ago, still going strong.
Based in that, next one will be lezyne too.
Posted : 23/12/2021 8:43 am
This is mine also, it's very good, but minus points for the fiddly on/off switch under the rubberised cover that's annoying to use with gloves.
I have a flashy one that i must have had for 10 years, but my favourite is a fibre flare. Really visible from a distance and because of the odd shape people seem to take notice
Posted : 23/12/2021 8:48 am
Got two of the rechargeable Aldi light sets, one is 4 years old, one is three. Great on the low solid setting for a marker when out at night with mates, the bright flashing mode works as daybright (as do the front lights in the sets). Bought another set this autumn in case these ones die, but no sign of it yet.
Yes, Exposure will be "nicer", but for £15 for a perfectly serviceable set of lights, I'm struggling to justify it, even owning 3 Exposure front lights.
Posted : 23/12/2021 8:52 am
I like the TraceR, but have had to return two for repair when water got in under the rubber cover and did bad things. Great light, but not infallible.
I also have a small, cheap-ish, rechargeable Evans-sourced light on the back of my helmet as a back-up. Works fine.
I really like the Exposure Mini Red-Eye thing on the back of a Joystick as a summer 'get me home' emergency option, but they're ridiculously small and easy to lose. They should come with a lanyard so you can secure them to something.
Posted : 23/12/2021 8:53 am
I've been using A bontrager flare for a few years now - use it in daylight on the road bike as well so not just when its dark. Only rear light ive had that has lasted that long and still works fine despite lots of soakings
Posted : 23/12/2021 9:01 am
I have been using an Exposure for a number of years but have found it to be a nightmare to switch on when going from trail to road and vice versa (switch off obviously).
I recently got a Knog Blinder Road S70? It is bright, narrow, has a lot of functions but is very easy to turn on and off by feel when riding. And that makes it a winner for me.
Posted : 23/12/2021 9:12 am
If you're using an Exposure Joystick, adding the Redeye Micro to its charger port is a no-brainer. It's cheap (under £15), and tiny but also incredibly bright, and as it's on your helmet it's at a good height. It shares the joystick's battery for power, but barely seems to impact battery life.
https://www.leisurelakesbikes.com/accessories/lights/exposure-redeye-micro-plug-in-led-rear-bike-light__4644
I run it with Moon Comet-X Pro on the seat post - it has various brightness levels and flashing rates, has a good battery life and seems pretty robust.
https://www.wiggle.co.uk/moon-comet-x-pro-rear-light
Posted : 23/12/2021 9:22 am
I just run a moon alcor which I've found works great, has ok battery life and is plenty bright enough for night rides which is what I use it for. Only costs about a tenner too.
Posted : 23/12/2021 9:48 am
Ideally one with a reflector and side visibility, but there is limited thought going in to most bike for road use.
On the utility/touring bikes I always have a rear rack so use either a big old Trelock with reflector or the Lezyne Strip Drive mounted horizontally on the back plate
On the MTB for surfaced transitions I use the Lezyne Strip Drive mounted vertically on the seatpost.
The Lezyne is 6 years old now and still works v well. I like that it’s mega-sturdy, rechargeable and has flashing modes and two static modes (high or low).
The ladder-style mounting-strap gives a lot of mounting options to various thicknesses of things.
If it ever needs replacing I’ll look at similar. I see they do an STVZO compliant Strip Drive with 270deg visibility, and also the Lezyne Strip Drive Pro 300 with a daylight flash.
Wiggle have one left at sale price
Posted : 23/12/2021 10:06 am
* correction
Ideally one with a decent reflector and also side-visibility, but there is limited thought going in to most bike-lights that are intended for road-use.
Posted : 23/12/2021 10:25 am
I have an old (10 years) Exposure Flare that I used to use for commuting. Think the newer version is the TraceR? Also have a Blaze for long road rides - others I’ve tried just don’t have the burn time (5+ hours) and the daybright thing seems good.
For MTB I have a Lezyne Zecto something or other. It was originally for on road but the battery only lasts a couple of hours. Other than that it’s good - different modes for brightness and flash patterns, USB recharging, quick to attach to seatpost or throw in jersey pocket, and currently £22 on Sigma. It’s ideal for getting me to/from the trails, I don’t use a rear light while actually riding trails though
Posted : 23/12/2021 10:28 am
Had a moon shield that I used for commuting 2 hours a day for a number of years. Was great until I got home one day to find it not on my seatpost. Fortunately I run a cheap Aldi lozenge light as a backup as well.
Now run an exposure Trace R in addition to the cheap Aldi light. So far so good, but since WFH has had less mileage than the moon. Has lots of different options for types of flash and pulse. Use the saddle rail mount which works well.
Posted : 23/12/2021 10:29 am
"Exposure TraceR"
Great little light but ruined by a stupidly fiddly on/off switch.
I've also had to return one for water ingress & the charge port moves around so it doesn't line up with the hole.
Posted : 23/12/2021 10:31 am
Forgot to say another feature I like about the Lezyne Strip Drive is a quick-check battery-indicator which I’ve found to very useful before setting off if I forgot to top up..
The battery indicator is built into the lens - green means the battery charge is over 75%
Green and red means it's between 75-25%
Red means that the battery is below 25%.
You can press the power button to check without turning the light on.
Posted : 23/12/2021 10:53 am
Exposure traceR
The switch on my sirius front light is a bit of a pain. But the traceR is fine. I like that I can remove it from the mount turn it on and put it back without stopping
PS we are well past the point of wanting a rear light that is bright as possible
Posted : 23/12/2021 11:22 am
Moon comet - it's the only rear light I've owned for more than 12months without it failing. 3yrs on still going strong.
Posted : 23/12/2021 11:25 am
Multiple Moon lights here, a mix of shields and nebulas. I like to run 2 on night rides, not so worried about them failing but more me having forgotten to charge them!
Sticking to the same brand for me means I have mounts on all the different bikes and the lights are interchangeable, just grab whatevers charged and go
Posted : 23/12/2021 11:32 am
I'd guess lots of different things! (but with a U in favour)
See.Sense for me. The Ace is ace. Support from the company is excellent too.
Posted : 23/12/2021 11:51 am
Light and motion vis 180, I have 2 the older is 8-9 years old, been dropped and bashed and still keeps working. Battery life is quite good and the flashing amber lights add visibility in town.
Posted : 23/12/2021 11:54 am
I used to go with multiple cheap, but since getting the TraceR I wouldn't go back as my average expenditure on lights has gone down as I've not had to keep buying cheap lights.
For road use though, I would argue that running two lights is a must so that if one fails you're not unknowingly invisible. The TraceR plus a helmet mounted Cateye Wearable X works well for me.
For intensive road in genuine dark (i.e. country roads vs urban streets) I'd want to use a light with a larger surface area - it gives drivers a better sense of distance plus avoid a blinding pinpoint of light. Something like one of the Knog Cobblers or similar maybe.
Posted : 23/12/2021 12:12 pm
Exposure Trace-r for me. Easy to use, battery life seems to last for an age. I have 2 of them.
I did have to return for the problem mentioned above (migrating charge point) but it was sorted quickly and f.o.c. They are relatively local to me in Sussex, so also a bonus.
Posted : 23/12/2021 12:16 pm
Alpkit Taus are brilliant and cheap. Easy to mount to seat stay as a second/backup light but plenty good enough as a main one too.
Posted : 23/12/2021 12:17 pm
See sense lights are the first lights I've managed not to destroy within a year. I've got the ACE as well.
Posted : 23/12/2021 12:43 pm
 aP
On my commute bike I have a B+M battery rack light and an old Blackburn seatpost light.
On my dynamo bike I have a SON rear lamp mounted so that is visible when packed.
Posted : 23/12/2021 12:51 pm
The shield shaped rear that came as part of the Lidl set in March '20 on the road bike, old ~2015(?) Aldi "Moon Comet - alike" on the commuter are the regulars.
Posted : 23/12/2021 1:21 pm
His 'n' Hers TraceRs.
Posted : 23/12/2021 1:49 pm
Any shouts for the Lezyne Zecto?
I had a TraceR for years no issues and then realised this winter that I must have lost it at the end of last.and have just been using my cheapy helmet light since, but need a proper replacement.
Posted : 23/12/2021 1:54 pm
I've just bought a Moon Comet X-Pro for the bike and a Cateye Orb for helmet duties.
Went with the X-Pro version as it has a few mount options, allowing for 2 or 3 bikes to use the light without faff.
Both are USB rechargeable to save messing with batteries and the Moon in particular amazed me with the intensity. I made the mistake of looking directly at it whilst cycling through the modes. Damn it's bright.
Both at a great price from Merlin.
Posted : 23/12/2021 2:05 pm
 momo
exposure TraceR with a saddle rail mount
Posted : 23/12/2021 2:18 pm
Unless they've upgraded the Zecto recently it's not a patch on a TraceR especially for daylight use.
Posted : 23/12/2021 2:53 pm
I've got a selection of Smart 1W LED's that have lasted for an eternity. Great little lights that aren't the most waterproof but can be easily dried out & run on AAA's. For a tenner I like these a lot. Comes with a versatile bracket that can be mounted on the seatpost or the back of your lid. I run two of these.
Lezyne Strip Drive. Solid light, rechargeable & has lasted about 4 years & still going strong. Downside is that the seatpost mount has it facing a downward angle. Still visible but not optimum.
MagicShine SeeMee 200. The brightest light & the most visible I've owned. Tons of modes including a brakelight function that I don't use & a bright LED that illuminates the back of the bike when the ambient light is low. However! I bought two of these last year at Christmas. One of these failed after six weeks & was quickly replaced under warranty by something that looked decidedly 2nd hand. Then the other failed & was replaced after a few emails with a new one. Then the first replacement failed & I gave up chasing as my emails were going unanswered. Life being too short etc.
I've bought Mrs Davesport a set of Bontrager Ion/Flare 200's for Christmas so I've got high hopes after reading the reviews. As yet; untested.
Posted : 23/12/2021 2:55 pm
As a driver too the ones that do pulse flash are the worst to be behind as they ruin vision and make it hard to judge distance, solid red is by far the best to be seen with
Posted : 23/12/2021 3:41 pm
 J-R
Moon Comets on my MTBs. Never had a problem, easy to recharge. I have a Catseye battery powered light on the road bike - it’s fine but would probably replace with Moon Comet if it fails, unless this thread points to a clearly better option.
are much more noticeable in my opinion, especially in busy night time city streets where there is more risk of not noticing a single steady small red light.
Posted : 23/12/2021 3:55 pm
Noticeable yes but hard to judge distance of cyclist
Posted : 23/12/2021 4:50 pm
One of these from Amazon, mainly because it’s saddle rail mounted. All my bike the frame and seat clamp are below the top of the tyre.
I also have a Exposure Red Eye that plugs into my Diablo.
EBUYFIRE ultra Bright Smart Bike Tail Light,USB Rechargeable Brake Sensing Bicycle Light,High Intensity Rear LED Accessories Fits On Any Road Bikes.Easy to Install for Cycling Safety Taillights https://www.amazon.co.uk/dp/B07V6CFS8F/ref=cm_sw_r_cp_api_glt_fabc_G9XNK58HWF265ARWJXNX
Posted : 23/12/2021 5:08 pm
I gave up on cheep lights. They were forget falling off of their mounts / shaping hands. Or, water or muck would get in and ruin them.
Now use a TraceR on the road bike which is ok. Difficult to turn on and off. Saddle mount very neat and very resilient. Cold weather really seems to diminish battery life - down to just a couple of hours.
Moon Nebula on the MTB, also with a saddle mount. Was a bit underwhelmed taking it out of the box but has been flawless so far this winter in the wet and mud.
Posted : 24/12/2021 12:39 am
I should have added im looking for one that will be used steady and in conjunction with the flashing Raleigh. So best running time, preferably rechargeable. I think something about 100-200 lumen would be better giving the flashing is more noticeable.
Posted : 24/12/2021 3:56 am
Tracr, years old. I knackered the charge port, they fixed it for £12.
It does the pulse thing which I prefer to flashing.
Got a link on helmet also by exposure which I think is the perfect combo for the ten miles I do on dark country A road.
I’ve also started using a cheapo px light on the cross bar aimed at the floor, it illuminates the water bottle and front triangle for side visibility and to actually see the water bottle.
Posted : 24/12/2021 5:13 am
Another Trace R with under saddle mount here. Only run that and it seems to be enough
Posted : 24/12/2021 7:01 am
I'm with davesport on the smart lights.  Been using the brand for about 25years, and I've built up a good collection of brackets so can have them seat post and seat stay mounted on multiple bikes.  Not many lights seem to be able to be seatstay mounted which is one of my preferred options as a saddlebag user.
Also run a B+M secula on the mudguard of the road bike, and planning to fit one on the seatstay too.
I tend to run low level lights on constant. And high level ones on flashing.
Posted : 24/12/2021 8:23 am
This. And most of the usb lights won't last for a full night's ride.
Posted : 24/12/2021 8:34 am
I'd like some decent options for this. Some people I ride with just mount a seatpost type clamp there and ride around with the light pointing at the sky not doing much... What solutions have folk come up with ?
Posted : 24/12/2021 8:57 am
And most of the usb lights won’t last for a full night’s ride
See.Sense Ace lasts over a week of commutes. If you're doing 10 hr night rides, that's something special 😀
Posted : 24/12/2021 9:04 am
I had a Niterider Solaris 250 but it fell off somewhere on a ride, it was very bright but not as bright or as visible from the side as the Cateye Viz 300 I’ve now got. Think I paid £26 but just seen them on Rutland Cycling for £23.
Posted : 24/12/2021 9:11 am
On my commuter I've fixed a strip of red LED's the full length of the seatpost with clear heat shrink & have a TraceR on the saddle rails.
Posted : 24/12/2021 9:46 am
Has the TraceR only ever been available in red? If I could get black or yellow I’d have one by now.
Posted : 24/12/2021 2:14 pm
I use one of the original Moon Shield's.
Really bright and has lasted years.
Will upgrade to the newest one when this eventually dies.
Posted : 24/12/2021 2:37 pm
Anyone running a Cateye Wearable X Rear USB Rechargeable Bike Light ?
Need a rear light for my backpack and this seems to fit the bill (have a Exposure TraceR under the saddle)
Posted : 24/12/2021 5:25 pm
not read the thread, I am a fan of rear lights that are large (and therefore visible) without being stupidly (in my view dangerously) bright.
Front lights - those that offer visibility and light up the road without dazzling other road users
Posted : 24/12/2021 5:33 pm
I'd like a recommendation for a rack mounted, but releasable, usb chargeable light with built in reflector.
I can't find something that ticks all the boxes.
Posted : 24/12/2021 6:45 pm
 FOG
I have a Magicshine (can't remember model) which is nice and bright but just doesn't last very long. It is particularly affected by temperature. I can get 2hrs in 7-8 degrees up but it barely reached 1.30 after being left in the garage at zero° for a couple of days. I always have to carry a spare when night riding
Posted : 24/12/2021 11:08 pm
See.Sense Ace lasts over a week of commutes. If you’re doing 10 hr night rides, that’s something special 😀
Seat post mount only and a ten hour run time in flashing mode only. Which is pretty useless for overnight audaxes.
Posted : 24/12/2021 11:38 pm
won’t last for a full night’s ride.
Not an ideal solution for many reasons (cost and weight for example) but a Hope district with a 6 cell battery will out last those 2 weeks of no sun they have near the North Pole, I reckon.
Edit. And some. 25 days, on the low setting, that’s with the 6 cell battery though, up to 200 hrs with the standard 2 cell battery.
Posted : 25/12/2021 1:28 am
Part of my commute, about 8 miles is fast A road and the idea of the helmet light is to hoprfully help the driver gauge my position ahead, but also the 9 miles in town for the light to be visible above the cars. I also ride a short strip of dual carriageway where there is a rise, the helmet light I hope gives the cars sight of it when I’m over the other side.
Normal road ride is just the Tracr on a saddle rail mount with the saddle bag under it.
Posted : 25/12/2021 7:03 am
This. And most of the usb lights won’t last for a full night’s ride.
I've been doing some research and I think the answer is a Bontrager Flare RT or Flare R. Adaptors are available for seat stays and mudguards, and the run time is 13.5 hours in low constant mode. Looks like a pretty good solution for overnight audaxes.
Posted : 05/01/2022 3:25 pm
I have a knogg one and an Evans own brand one, neither were expensive and both keep working despite year round commuting etc. had them both for at least 3 or 4 yrs. use one on pulse and one on solid so that drivers can perceive the distance as well as actually recognising that it's not just another red light thing.
Posted : 05/01/2022 4:23 pm
Wayyyy more than a 10 hour run time, but yeah, there's no static setting, only flash.
Posted : 05/01/2022 4:26 pm
