OK, admittedly not as ghetto, therefore not as cool as the pop-bottle version, but as I had one of these Ronseal creosote-sprayer hobbies in the garage, and a very stubborn Conti X-King that just refused to play, it got cracked out...
Bit of 6mm internal diameter tubing and a pair of mole grips, job's a good un...
The beauty of the Ronseal (other varnishes are probably available) thing is that it has a built in pump and a pressure release valve set at 45psi. At 5L capacity that's enough stocked energy to pop the beads on most tyres, I reckon.
Less fun than pumping a Coke bottle up to 100psi, granted.
Cool! And the valve and logo are aligned!
Stick a presta valve on in place of the pressure valve and it will go higher than 40 psi. Then add a proper track pump tube and chuck and you have my set up.
Have something very similar myself. Works very well and was cheap and simple to make.
Min had a trigger on it for the spray so I added the tubing after that so no need for the mole grips. I roughly checked the safety on mine using a track pump and it was about 60psi. A 3L sprayer got a 2.2" 29er seated comfortably. I'm sure someone could figure out the sizes and pressures that would work (Ideal gas/Boyles law) but got for about 5L and it is probably going to work unless it is a fat bike.
That's a really flippin good idea!
^oldnpastit^ 'course the valve lines up with the tyre label! Whaddya take me for?
^jonba^ now why didn't I think of that? Doh!
Shirley if the tyre wont inflate with a basic floor pump then the fits too loose and needs more tape? Fooling the tyre into inflating with a high pressure pump will leave the tyre prone to burping?
Cool set up though.
[url= http://singletrackmag.com/forum/topic/ghetto-tubeless-inflator-mk-vii ]Go high pressure[/url]
120psi will seat & inflate 2 tyres easily. 🙂
For me I use standard tyres. I find a short sharp blast of air is needed to seat some tyres - particularly if they've been on and off a couple of times. I've never had a problem with burping. Some tyres I managed with the track pump but this is 100% effective with no soapy liquid etc. so minimal faff which is great.
^enfht^ as the trye beads actually seat on the 'shoulders' of the rim and not in the well, not convinced that more rim tape would help a lot. Annyhoo, these are Mavic Crossmaxes with the snazzy Mavic UST sealed box-section rims, so no tape involved.
I think the issue is how well the rim/tyre combo match up - for example I have never had the least problem with any tyre from Hutchinson or from Maxxis with these rims - they all seal with the least puff from a track pump, regardless of whether they are tubeless ready or not. Schwalbe - massive PITA, really hard to get 'em to pop. These Contis were a real struggle too until I broke out the Ghetto inflator 🙂
Remains to see if they are more burp-prone in action....will report back.
