I just bought an '08 Cube Fritzz frame with rear Maxle. What is the diameter of a Maxle? a quick google says it's probably 12mm, but the previous owner mentioned something about a 10mm hub 'working fine'. Am I right in assuming this is 2 seperate things (i.e. 10mm bolt-thru will not take a Maxle)?
Rear Maxle is 12mm.
12mm
this is the [url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=44142 ]QR[/url] and it answers your question.
not cheap I am afraid.
Thanks (like an idiot I checked on CRC, but missed the bit about 12mm). Maxle came with the frame 🙂 So I guess I only need to fork out for a 12mm adapter.
this might depress you warcow, but hopefully as you will see from my last post there is a solution.
http://www.singletrackworld.com/forum/topic/hope-12mm-rear-axle-snapped
MadBillMcMad - Member
this might depress you warcow, but hopefully as you will see from my last post there is a solution.http://www.singletrackworld.com/forum/topic/hope-12mm-rear-axle-snapped
That only relates to the maxle lite rather than the maxle, doesn't it?
retro83,
correct
