Thanks for help guys!
OK, [b]NON[/b] Evo rear hub, currently 135x 12 Maxle.
Converting it to 135x10 to fit a Dartmoor Primal.
So... just about to order these items, can you guys check they are right please? Never run 135x10 before. Oh, can I reuse same bearings, as they run fine??
[url= http://www.ebay.co.uk/itm/331280595978?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]New axle for hub,[/url]
[url= http://www.superstarcomponents.com/en/10mm-rear-qr-through-axle.htm ]Superstar 10mm QR[/url]
[url= http://slam69.co.uk/dartmoor-primal---26650b-frame-7439-p.asp ]Onto this frame, spec on this page.[/url]
HUGE thanks guys, as always.
Ah, gowan, gowan, gowan... have a quick click so I can pull the trigger on the bits. 😉
Close. End caps needed as well. 🙂
Bearings are the same, good time to check them when swapping the axle.
B*gger! I was nearly there! lol
Thanks to crofts too, will check them when removed.
Cheers guys!
