OK so I went N-1 and I meant it, but now I have a set of plus wheels and tyres and some forks and basically about 90% of another bike just sitting about, and I got to wondering what would work with them...
Obviously the smart thing, if you want a B+ hardtail, is to buy one but that means boost, and a) boost can **** off and b) the plus wheels I have aren't boost, because they're for my non-boost full suss first and foremost.
Soooo. What is there out there that's not madly expensive, can take a 2.8 schwalbe rear as a minimum, ideally 3.0 (with 1x), works as a 29er, and is for... 120-140mm fork let's say, and 31.6 so I can fit my droppers in it. I'd like decently long, slack and reachy too.
Ragley Bigwig comes to mind- not really as long as I'd like and pretty hefty but I enjoyed it as a 29er. But what else is there? So I can add it all to me ebay search list and get annoyed when nobody ever has any to sell
I've got a 2014 bigwig you can have for 100£ + postage. Email in profile for pictures
Is the new sherpa boost?
Solaris was my first thought but isn't quite there. You should buy it though.
Genesis longitude or tarn may get close ish?
Kinesis phase? Swing and a miss, it's boost.
Ditto Saracen Zen
Just flick through the b+ conversions thread?
The new karate monkey looks like it might do.
Edit.
Bum, 30.9 seatpost
@treklee, do you know how it does for big stupid tyres?
swanny853 - MemberJust flick through the b+ conversions thread?
That... that's depressingly obvious, now you say it. Cheers! I will do that, great suggestion.
Genesis look to have some real contenders, their range is pretty confusing to me but I'll try and get into it. I'm a Cotic and posh steel fanboi from way back but I dunno, the Solaris has never done it for me for some reason, and it's 2.8 only.
oooooh sherpa.
http://www.bikerumor.com/2016/01/20/lindarets-boostinator-converts-your-standard-mountain-bike-hubs-to-boost-110148/
Boostinate it?
Thats a possibility, even swapping between boost and non boost frames- I've seen a hightower run with 29er wheels, a boostinator and no re-dishing. Plus tyres may be a tighter fit though
New P7? Definitely not boost, not sure on max tyre size.
New Sherpa comes with 142 bolt through as standard but 135 and s/s are given as options.
Clearance is stated for 3" tyres.
Hopefully I'll be able to confirm this later this week...
Problem is non-boost forks and tyre clearance. Pics on the other thread...
boost can **** off...
On a serious note, it's worth looking at the Lindarets Boostinators ( http://www.lindarets.com/boostinator/). Using a set on my Hopes with no problems at all, and it future-proofs the frame to some degree.
Pipedream are working on a new hardtail:
[url= http://www.pipedreamcycles.co.uk/evolution-and-possibly-the-ultimate-27-529er/ ]Pipedream Sirius[/url]
I am currently torn between this and a Shan GT, Geometry figures will be realeased for the Sirius soon apparently.
2017 Kona Unit, I guess it will be available as frame only.
Last Fast Forward is exactly what you want, and it's a brilliant bike, but I'm guessing you'll rule it out because you'd have to redish the wheel 🙂
Boostinator would either need a redish every time I move the wheels, or enough tyre clearance to run the wheeloffcentre, which probably isn't going to work out with a big tyre. Definitely not in the remedy, I'm taking the piss there with a 3.0 anyway, it fits in much the same way as I fit in my old jeans 😆
What is that, Mashiehood? Apart from, obviously too expensive for me. Lovely though!
North wind - it's an Open One+
Cor. I mean, nope, but still, cor.
