Nomad V4 vs capra
[Closed] Nomad V4 vs capra
5 Users
Recently bought a capra, really liking it. I've ended up with (won't bore anyone with the details) a brand new nomad V4 CC frame, i have all the bits to build it too.
Plan was just to sell on the nomad but temptation to keep it is strong.
Can't work out which would be better....
Geometry, nomad gains 15mm in reach, is a little shorter in the seattube, on paper the nomad BB is lower, but reckon there's not much in it once the bike is sagged (since the capra is so progressive in leverage rate).
Flip chip - on the capra i ride a little less sag on pedally/less gnar to steepen things, bit more sag when i want it lower and slacker.
The nomad has to be lighter right? vs an al capra.
Can put a bottle cage on the nomad.
Something that sold me on the capra is that the anti-squat isn't too fierce, hence loads of pedal kick-back, with the capra i have the choice of smaller chainring with more anti-squat for pedalling or bigger chainring and more neutral suspension for uplift days, with the nomad you dont get the choice.
The nomad is going to be a little lighter, can have a bottle cage and may pedal a little better, is that a pretty good summary?
Anyone ridden both and came to the same conclusion? Anything special about the nomad V4 i'm missing?
Interested in the super deluxe shock with bearing eyelet, wildly better?
Posted : 04/10/2017 4:00 pm
My guess is tgr V4 will simply descend better, the leverage ratio is uttetly sorted for gravity duties. Ill take a look at hee leverage numbera but Id be surprised ised if it pedals better.
Posted : 04/10/2017 5:07 pm
You're in a position where you don't need to ask the forum. You can build the Nomad up and compare them - then sell the "loser".
Posted : 04/10/2017 5:21 pm
I bet the nomad pedals better.
Posted : 04/10/2017 5:24 pm
Thinking as soon as I test I lose potential sale value on something which is no longer box fresh
Posted : 04/10/2017 6:08 pm
If value is a metric.. Keep the capra. I doubt you could slip a fag paper between them performance wise. The capra wins only due to value.
Posted : 04/10/2017 6:17 pm
