Noisy SRAM Code RSC
[Closed] Noisy SRAM Code RSC
9 Users
has anyone found any pads that are quiet in this awful weather?!
my original sram pads lasted ages but were noisy, tried some uberbike sintered and they are even noisier!
any suggestions? back to organic for quietness?
Posted : 18/11/2019 4:15 pm
Rotor definitely centred?
Posted : 18/11/2019 6:39 pm
Yep all lined up cleaned and torqued
No vibration or rubbing
Just loud honking noises
Posted : 18/11/2019 6:59 pm
Best I've found so far are the new blue (ebike) pads from Uberbike
Posted : 18/11/2019 10:07 pm
I thought it was just me that had vocal brakes. I'll look those ebike pads up. Thanks for the tip dropoff
Posted : 18/11/2019 10:25 pm
Bike outside vehicle being transported? Could be the road grime coating the rotor. I had this on 2 bikes that had been transported on a rear rack.
Couple of sharp pulls helped but didn't resolve it.
Good wash seems to have though.
Posted : 19/11/2019 6:48 am
So far my standard (sintered) sram pads seem to be doing ok in Code R’s and guide RE’s. Both using Centerline discs.
I’ve had success with uberbike race matrix in standard Guides and have some of those blue e matrix (or whatever they’re called) pads lined up for the codes when the standard pads wear out.
Posted : 19/11/2019 7:22 am
the uber pads are the noisiest of the lot so far
I might just get some brand new sram sintered and start again with a full clean etc
bike never transported outside on vehicle so not that, and all lined up etc and no rubbing
Posted : 19/11/2019 9:01 am
Aye, got some white pads from Uberbike and they are about G flat by my ear when they get a bit of muck on them. I seem to remember the original SRAM organic pads were pretty noisy as well. Rear for me is worst. Might give the e-bike versions a go next.
Posted : 19/11/2019 9:46 am
Isn't it the rotor that causes the noise, hence why other brakes are better as they have an alloy carrier.
I've heard very good things about the Trickstuff pads but can't comment on noise levels.
Posted : 19/11/2019 9:51 am
I ran the stock sintered pads in my code RSC's till they wore out, was put off when they cost £30 a pair to repalce, so instead I picked up 4 pairs of Uber E Race Matrix for nearly the same price and have not had any noise issues yet.
Posted : 19/11/2019 10:11 am
ive managed get some genuine sram ones on ebay cheap brand new so ill try them first again, will give everything a good clean first too....I don'tmind paying top whack for pads if the noise is resolved as the sram sintered last ages too....
if this fails im just going to run organic all year round and buy in bulk for when they run out, as im 99% sure they'll be pretty much silent even in the wet
Posted : 19/11/2019 10:57 am
I've run Uberbike Semi-metallic and Race Matrix on SRAM Guide, Hope E4, Hope V4, Shimano XT. Never had noise issues with them.
Sintered are always going to be noisy though, but overly noisy is likely to be contamination.
Posted : 19/11/2019 8:25 pm
