No Tools - 'Kn...
[Closed] No Tools - 'Knocking' Shimano Press Fit BB Out Of Shell
8 Users
The pressfit BB on my Defy 1 is creaking like a Plymouth harlot's bedsprings when a battleship's returned to port. It's horrendous, and spoiling my time out on the bike.
I want to remove it, squirt a few litres of Loctite 641 around it and refit it (hopefully to stop the creaking). However, I don't have the proper tools and I'm also a bit skint at the moment, so won't be buying any. What would the fellow tool-improvising pressfit BB mechanics of STW recommend using for removal of a pressfit BB in such a way that it's still functioning upon reinsertion?
I've seen a couple of posts online about improvising to remove the BB but none are specific about what, exactly, to use, nor whether the BB is reusable afterwards.
Cheers 🙂
Posted : 16/04/2014 12:01 pm
Headset removal tool. Works on mine. Just be careful with where it actually contacts the BB though.
Posted : 16/04/2014 12:05 pm
My one was / is plastic, so it's easy to damage the cups with the usual screwdriver and hammer approach. It does come out easy, though, so I'd prob just try and softly tap it out with a carefully placed screwdriver plus a rag around the end.
If that sounds too agricultural then try and borrow the tool? Plenty of them around nowadays.
Posted : 16/04/2014 12:07 pm
Don't have a headset removal tool either, I've always used a bit of wood but headsets are metal and the BB's plastic, so more fragile.
(That reminds me, I need to start another post. "How do you remove a stubborn On-one Smoothie headset from a frame without a headset removal tool?" 🙂 )
Posted : 16/04/2014 12:09 pm
 tomd
Cut off bit of broom handle and a large mallet. Trim girth of broom handle to suit
Posted : 16/04/2014 12:16 pm
Hammer and screwdriver, just be careful (not too careful you need to get it out and hitting things with hammers if fun)!
Posted : 16/04/2014 12:19 pm
Is a broom handle wide enough? I was wondering whether a bit of bathroom waste pipe might do it? Cheers.
I hate BB30/71 BB's. Why didn't my Defy come with an HTII ? 🙁
Posted : 16/04/2014 12:20 pm
Should be too big to fit through the hole! Mine is.....
You should be able to knock it out with a screwdriver but the tool is pretty cheap
Park Tool BBT90.3 has the correct rocket tool and the adaptors to press it back in again 🙂
Posted : 16/04/2014 12:21 pm
headset/BB removal tool - 10-12" copper pipe off cut from ebay, 5-10 mins with a hacksaw and file, some judicious bending and you're done. wooden plug in the hammer-y end if you're feeling pro.
I messed up the first cut on mine. Looks like a dog's breakfast but works a treat.
Posted : 16/04/2014 12:23 pm
PP - mine works just fine. I guess it just depends on the size of your tool 🙂
Posted : 16/04/2014 12:25 pm
I just used a piece of wood ( pine ) trimmed to fit, couple of sharp tap with hammer, worked fine on my commencal, have changed two now.
Posted : 16/04/2014 4:54 pm
