No pop, will I burp...
[Closed] No pop, will I burp?
6 Users
JUst tubelessified my old rims, mavic EN 321's of uncertain vintage (c.2008-9?) got them up and holding air but no pop as the bead snapped into the rim? are these about to burp the jizz at the first hint of a corner or is it all happy happy joy joy? Got em both up to about 60psi so don't really want to go much further than that.
Working from home's good innit?
Posted : 30/06/2015 9:53 am
Is the bead actually seated? can you see the line/join evenly all the way around on both sides?
They don't always 'pop' audibly but you need to make sure it is properly seated all the way on both sides, other wise you'll be in for at least a wobbly tyre, if not a big burpgasm and jizzy death 🙂
Posted : 30/06/2015 9:57 am
Well, it looks OK, have to test ride i guess, if you hear a bang, it's me getting the full load.
Posted : 30/06/2015 10:00 am
When I used non tubeless specific rims I didn't get a pop as they just went into place. Since move to Stan's rim I get massive pops combined with a really strong seating on the rim (i.e. need to push it off the rim when deflating tyre)
Posted : 30/06/2015 10:04 am
My old 717's didn't pop and stay up fine. Run them at about 20psi and no burping yet but it's ridden by my other half not too aggressively.
Posted : 30/06/2015 10:32 am
I used to run some EN321s ghetto with inner tube and then switched to gorilla tape and they were both fine as long as I didn't go below 30psi but back then I was 18 stone plus!
Posted : 30/06/2015 10:38 am
well a quick razz round the block says alls good, they're up around 35 though, see how we get on.
Posted : 30/06/2015 10:43 am
I'd hazzard a guess that non-tubeless rims wont go pop, because they dont lock the bead in place.
Posted : 30/06/2015 10:54 am
Well, yeah, but with tubes you got a noise as everything settles down and I've certainly heard it ping to place.
Posted : 30/06/2015 10:58 am
