Newbie Question on ...
[Closed] Newbie Question on Pro2 Hubs
5 Users
On my 1st set and cant get my cassette tool on to tighten the cassette lockring on as the qr axle is too thick. Do I need to remove this? And if so does it pop out like the fronts? Or do i need to change my cassette tool? Thanks.
Posted : 15/09/2010 4:55 pm
It would be better to get a cassette tool that fits over the axle - mine does and its just a cheapie.
But for the meantime I see no reason why you can't take the end cap off to do up the casette - the only issue is the freehub could fall off while you do it.
Posted : 15/09/2010 5:10 pm
Is it a sram/shimano cassette? I've got the same problem with one of my hubs - only one mind, the shimano tool won't fit, but the Park one will. The Park Tool remover has a thinner body. Can you borrow one? Or ask to try (then buy) suitable at your lbs?
Posted : 15/09/2010 5:32 pm
I don't think that you will be able to get the end cap back on after you have screwed the lock ring on will you?
Posted : 15/09/2010 7:29 pm
Good shout folks, sounds like it could be another tool for the box! I'll try the 'try before I buy method from the lbs'. Always good to support them. Just wanted to be sure before I open the hubs up.
Posted : 15/09/2010 8:47 pm
Check your cassette tool first and see if the middle bit that sits in the axle is removable or not. I had this issue and simply pulled the locator bit out of my tool and it now sits on perfectly.
Posted : 15/09/2010 8:52 pm
