My LBS have got my full 1x11 group in, apart from the 30t chainring. It unfortunately seems to be showing a late October delivery.
I did order a 96mm p.c.d chainring from CRC but the pattern is not symmetric on the crankset so it doesn't fit!!! So basically i am asking what rings people are using out with Shimano OEM.
Also if someone has time could you please take a photo of the inside of the crank where ring bolts on and post it, if you get a chance?
Cheers, Allan
One Up do rings to suit.
http://int.oneupcomponents.com/collections/all-products
XTR 30T will fit and is available. Not cheap mind, but stainless steel teeth, so should last very well.
30T XT due mid-Sept though, so not far away.
My LBS were told mid October i think, may have changed though.
That one up seems the job?
I've not got an M8000 crank but I've used a few One Up rings and they work well and last quite well too.
Date from Madison is 18th September.
The delivery date for the XT rings came forward a month or so just recently.
I've got the one up with 30teeth works well.
