New XT brakes M785-...
[Closed] New XT brakes M785- replacement hose ?
3 Users
I think I've got a little leak out of the crimped end at the caliper, seems to be a common problem so anything better than the 'new' BH90 hose ?
Posted : 01/05/2012 9:19 am
The tubing diameter is different - so old-style Shimano tubing isn't any good, apparently. I don't know if there are any aftermarket kits, but if they are they'd need to be different diameter to older Shimano brakes.
Is there anything wrong with the Shimano hose?
Posted : 01/05/2012 10:23 am
whatever you replace the shimano cable with, make sure that all the appropriate connectors are supplied before you launch into the task.
sounds kinda obvious, but in my case I purchased a (i) jagwire hose and (ii) the connector kit for m785 xt brakes.
problem is that the connector kit does not include the 'female' connector that screws onto jagwires brass banjo. so I am trying to get an avid? banjo to work with the system.
not taking a poke at jagwire as such, but maybe their instructions and web videos could be more idiot-proof?
good luck!
Posted : 01/05/2012 10:32 am
