New style revs - wh...
[Closed] New style revs - what size rotor with no additional mount?
4 Users
Can i run a 180mm rotor without an additional post mount with a shimano caliper
Posted : 15/06/2012 8:11 pm
no, 160
Posted : 15/06/2012 8:14 pm
sure?
Posted : 15/06/2012 8:24 pm
I'm sure.
Posted : 15/06/2012 10:21 pm
as above 160mm
If Rockshox(SRAM) had made it direct 180mm post mount it'd have been a PITA to fit 185mm Avid(SRAM) rotors
Posted : 15/06/2012 10:34 pm
no it wouldn't as they come with (avid brakes) the 5mm of conical washers, lyriks are 180mm post mount
Posted : 17/06/2012 8:20 pm
Well, either way on Revs I'm sure some people will want to run 160mm discs.
But it's 2.5mm of washers 😉
Posted : 17/06/2012 9:07 pm
5mm of conical washers?
If they made up the 5mm to run a 185mm rotor onto a 180mm lyrik, then you'd have to run a 165mm rotor on a post mount 160mm fork?
Posted : 17/06/2012 11:14 pm
aye 2.5mm of conical to make up the difference to run a 185mm rotor on lyriks.
JAmes some forks have a minimum rotor size (like Lyriks do) not understanding what point you are trying to make.
I wanted to know if Revs were 180mm post mounts like lyriks are thats all
Posted : 18/06/2012 9:27 am
