Thinking about purchasing a new stem to help sort out problem I get in the lower part of my back. Currently got a stem with a 5 degree rise. Will I notice an increase in 1 degree with a new 6 degree stem?
It moves the bar by less than 2mm on a c. 100mm stem.
Personally i would notice it but I would soon (as in 10 minutes) get used to it.
Might be worth getting a cheaper stem with more rise, just to see how it feels before buying an expensive replacement that might not make any difference. You can always keep the cheap stem I think it's good to have a selection of inexpensive kit to experiment with.
only if you write reviews for magazines 😉
No. You won't notice it. Not ever.
OK cool, might go down the route of some new bars then with a higher rise than my current ones which are 1.5"
with a 100mm stem the difference is 1mm less reach and 2mm higher
with a 80mm stem the difference is 1mm less reach and 1mm higher
with a 60mm stem the difference is same reach and 1mm higher
[assuming a 70 deg head angle]
see http://alex.phred.org/stemchart/Default.aspx
No you wouldn't! If no one told you? Your bars flex more than that!
Only if you would notice that your saddle is 2mm lower than usual!
