New SLX brake calip...
[Closed] New SLX brake caliper fouling on rotor
7 Users
Just fitting a new SLX caliper replaced under warranty. For some reason the caliper housing is fouling on the rotor - tried centering it up by eye and with pads in, but as soon as I nip up the bolts, the rotor starts cutting in to the body of the caliper.
Is a little bit of 'wearing in' normal on a new SLX. Doesn't seem right and don't want to die!
The mount adapter hasn't been changed, BTW.
Cheers in advance,
BTM
Posted : 01/02/2014 10:09 am
They sometimes move as you tighten the bolts. Iirc top bolt tends to push the top in towards the wheel and opposite at the bottom. I think small variations in the finish on caliper and mount/adapter affect any one calipers propensity to move. I have four shimano brakes. One always slips the others do not.
Posted : 01/02/2014 10:30 am
What do you recommend, nip it up and let the rotor machine away the but of caliper body that's fouling it? It doesn't sound nice!
Posted : 01/02/2014 10:53 am
I wouldn't. I'm a bit unsure from your OP which part of the caliper is contacting the disc, I'll presume its to one side?
Have you tried loosely fitting the caliper, installing the pads, refitting the wheel and squeezing the lever whilst tightening the caliper bolts?
Posted : 01/02/2014 10:59 am
Yes, done all that. The edge of the rotor is contacting the caliper - it's not side rub, so it's like a circular saw cutting into wood if that makes sense. A slim washer would sort it I guess, but it's not *supposed* to be that way.
Posted : 01/02/2014 11:34 am
i had this on my rear slx caliper, which is used with a hayes rotor.
the front, which has a shimano rotor doesnt have this issue.
ended up using a slim washer to fix it.
Posted : 01/02/2014 11:40 am
I had the same issue with my XT brakes, I'm thinking it's down to the calliper mounts on my bike needing faced. In the end I placed a washer on each bolt for the disk which spaced it out enough to get the caliper centred properly.
Posted : 01/02/2014 11:51 am
I had a similar problem when fitting some shimano brakes then realised I had the mount adapter upside down so I'd recommend checking this
Posted : 01/02/2014 12:24 pm
Is it a Shimano rotor? If so then it sounds like a washer to space it out a little is needed.
Posted : 01/02/2014 12:27 pm
Adapter is the right way up, think I'll try a slim washer.
Posted : 01/02/2014 12:58 pm
Not a shimano rotor but the caliper has been replaced like for like, worked fine with the old one.
Posted : 01/02/2014 12:59 pm
Ah, well. Not all rotors are created equal. I had the same problem with some other brands rotor. Spaced it out with a washer in the end.
Posted : 01/02/2014 1:47 pm
