New rock shox 2018 ...
[Closed] New rock shox 2018 for 650b plus?
3 Users
Currently getting bits together for a Santa Cruz Chameleon build.
I initially plan to run it in 650b plus mode.
Am I right in thinking i would need 29er pikes/lyrics in boost format?
Do the 2018 ones have more tyre clearance than 2017 ones? I was under the impression the 2017 ones even in boost have the same chassis as non boost.
I want plenty of tyre clearance and plan to get a 29" set of wheels so I can switch between 650b and 29.
Posted : 24/05/2017 5:35 pm
If they are boost then the chassis cannot be the same.
Posted : 24/05/2017 7:28 pm
Sorry what I meant is I understand that a 2017 Pike, boost and non boost have the same CSU, meaning the width of the lower legs are the same distance apart and have the same tyre clearance.
Posted : 24/05/2017 9:19 pm
2017 you needed 29er boost. 2018 you only need 29er unless your running 2.8 or less. In which case a 650 fork will also work.
Posted : 25/05/2017 8:05 am
