New Pikes not holdi...
[Closed] New Pikes not holding air.
5 Users
Hello, i got a brand new set of Pikes, put them on and put the correct amount of air in, 3 hrs later
and most of the air has leaked out, has anybody else had this and is there an easy fix? thanks
Posted : 30/08/2014 7:05 am
check there is nothing caught in the valve (visually) - but if not then warranty as new
Posted : 30/08/2014 7:09 am
The ex had a set that arrived like that. Return to seller if it's not the schrader valve thats leaking. This was coming from the top cap somewhere not the valve.
It's probably an o-ring that's missing/nipped etc but better let them fix it all in case it's not just that wrong with it.
Posted : 30/08/2014 8:26 am
Something i've noticed with the Pikes when you uncrew the air cap from the top of leg I get a very slight pressure release feeling on the final turn open. Air pressure is always 50psi though as I last pumped it up too. Is this a miniscule leak from the air valve or do the top caps always build up a bit of pressure in air forks?
Posted : 30/08/2014 9:23 am
 Euro
Mine were like that from new. Tightened the air valve (try that) but no joy. Had to send them back (Merlin) and wait a few weeks while they were warrantied. Note in the returned box from SRAM mentioned replacing the valve and seals. No problems since.
Posted : 30/08/2014 9:47 am
Which explains why the guy from Merlin said he's never seen any like that before 😉
Posted : 30/08/2014 9:51 am
 Euro
Default CS answer Mike. But your ex's could have been the first ever - mine were 6 months ago.
Posted : 30/08/2014 10:08 am
this was last week...
Posted : 30/08/2014 10:09 am
Thanks for your replies, i will send them back on monday, sadly i am going to wales on thurs for a few days riding, and that is why i went for these forks, dought if they will be ready for then. Pants.
Posted : 30/08/2014 11:12 am
