New Ohlins air shoc...
[Closed] New Ohlins air shock!
19 Users
Just saw this posted up on mtbr
[url= http://www.specialized.com/li/de/ddb/www/#products/B/mountain/enduro/sworks-enduro-650b ]http://www.specialized.com/li/de/ddb/www/#products/B/mountain/enduro/sworks-enduro-650b[/url]
If this rides anything like the coil version this could be the new king of air shocks! Will probably be a year or so until it's available aftermarket though.
Posted : 08/07/2015 6:15 pm
 LoCo
Posted : 08/07/2015 6:18 pm
They have 160 mm forks on the way too !
Posted : 08/07/2015 6:21 pm
 LoCo
Posted : 08/07/2015 6:37 pm
Ohlins on a bike, well **** me!
Posted : 08/07/2015 7:18 pm
Oh come on Kimbers... you can't say that without posting pics as well! 😛
Posted : 08/07/2015 7:25 pm
Also an Enduro Evo with 180 mm triple clamp Boxxers (and coil Ohlins shock).
http://www.specialized.com/li/de/ddb/www/#products/B/mountain/enduro/enduro-expert-evo-650b
Wasn't expecting that.
Posted : 08/07/2015 7:33 pm
 MSP
The enduro evo has been out for a while.
Posted : 08/07/2015 7:34 pm
Oh OK, the triple clamp forked evo have passed me by.
oooff, that S-Works though, I'm going to have to take a moment.
[img] http://s7d5.scene7.com/is/image/Specialized/146604?$Large$ [/img]
Posted : 08/07/2015 7:37 pm
Awesome news. I guess I should be hoping for them to be available aftermarket in 2016 🙂
Now the big question is how it would compare in terms of performance to the Push 11-6 shock...
Posted : 08/07/2015 7:45 pm
No pics, we were staying in the same Bunkhouse at EWS A super fast Swedish enduroist , and get nice chap Robin Walner and his brother, both running online front n rear, no decals on them but I had a nose in the bike store and they said ohlins in paint on the back
Some pics here
https://www.rootsandrain.com/rider2974/robin-wallner/photos/?race=3031
Zoom in on this one
https://www.rootsandrain.com/photos/1009330
And on his brothers bike
https://www.rootsandrain.com/photos/1009331
Posted : 08/07/2015 8:23 pm
Am going to get this asap when they're available as have been lusting over the coil versions for a while now.
Plus it will be a well worthy upgrade over a Fox RPL, please Ohlins, bring out the new air in 190x50.
Posted : 08/07/2015 9:24 pm
More info on the new Ohlins air shock: http://www.vitalmtb.com/product/feature/Sneak-Peek-New-Ohlins-Air-Shock-Featured-on-2016-Specialized-Enduro,344
£499 and available to the existing Specialized Enduro bikes from September this year.
As usual, there are some interesting posts in the comments section:
This isnt that hard... The Enduros will probably get SWAT doors when the engineering team has enough resources (aka quits gherkin it on proprietary road bike parts that will likely be recalled early 2016).
Second, this shock is specifically designed to deal with outdated bad suspension design. Proprietary mounts, proprietary length/stroke... Exciting! PUSH wont do a shock for the Enduro 650b over 190lb rider weight because the ratio is garbage.
This shock is a bandaid for bad frame shock rates, not new tech that will have any trickle-down to applly to any other brand bike. I feel sorry Ohlins was talked into working with these clowns.
Any idiot should deduce that this bike/shock is a complete waste of money until redesigned in 2016. And it will still a be a waste until proprietary mounts and stroke/lengths are gone.
Way to go Specialized and Ohlins (slow clap......)
Posted : 26/07/2015 11:31 am
There are a fair few guys over here in Sweden that run the rear coil shock on their enduro bikes. They rave about them.
Posted : 26/07/2015 11:43 am
That says more about the limitations of Push than the Enduro
Posted : 26/07/2015 3:04 pm
http://www.mbr.co.uk/news/product_news/exclusive-first-look-ohlins-stx22-air-shock-video-330528
I wonder if it will really be comparable to the coil? Or will it fall apart like the CCDBInline? Seems a shame Ohlins ditched the spherical bearing for the air shock, as that would seem to mitigate problems the Inline had with lateral loading from the custom yoke.
Posted : 21/08/2015 12:39 pm
Seeing as Ohlins 'thing' has been that they have a proper double barrel/twin tube damper where the competition only had single tube de-carbon style dampers, isn't the STX a bit of a step down in theoretical performance? Or maybe that's the idea, to get Ohlins shocks on mid range bikes, I'm guessing the Fox Float market segment is huge compared to any other they're involved in.
Posted : 21/08/2015 1:53 pm
I'm not quite sure I understand what this twin/single tube thing is about
Is twin tube the same thing as a piggyback - is the rock shox monarch plus a twin tube?
Posted : 21/08/2015 2:20 pm
Nope, all mountainbike dampers apart from the CCDB and the old Romic twin tube are what are known as de-carbon dampers (invented by Mr De-Carbon I presume). they operate on the principal that the shaft of the damper is displacing some fluid into the pigyback* and there's a damping valve between the shock body and the pigyback, there are also dampers on the piston on the shaft which do some of the damping but are non adjustable. The bigger the shaft the more control you have (see the progression from a Fox RC4 Vs the original VanRC, and the DHX in between), but only to a point, bigger shafts have more friction so you want to minimize that at the same time.
A twin tube has a pigyback to accommodate the displaced fluid, but there's no damper between the shock and the pigyback, it also has fixed dampers on the piston too. But it also has a tube within a tube (hence twin tube), which means the dampers on the piston can be almost entirely closed and the piston is effectively pushing all the damping fluid (not just a fraction) through the adjustable dampers (which are often mounted on the pigyback for convenience), the returning oil re-circulates through the outside tube to the other side of the piston.
The two main advantages are you're flowing a lot more oil through the adjustable damper, which is why a CCDB can be tuned for a lightweight or heavy rider or different bikes as they can have a really wide adjustment range, without having to dismantle it as with Fox/RS (which is why fox/RS chocks come in 3 different compression and rebound tunes). It also means the hot oil after it comes out the damper is forced round the outside of the shock, which cools it before it goes back into the main body of the shock, and cooler (or at least consistent temperature) oil is better.
*it doesn't have to be a pigyback, it might be an internal reservoir inline with the shaft like on a Fox float or a normal monarch shock or the CCDB inline.
Posted : 21/08/2015 2:59 pm
thisisnotaspoon - Member
Chris De Carbon. Honest!
Always a wee bit skeptical of Ohlins tbh, is this going to be a pro level shock or is it going to be disappointing consumer level stuff like so much of their motorbike range? It's not a guarantee of quality, that name, they could dip a jobby in gold paint and people'd bolt them to their GSXRs. But they can do good stuff when they want to so hopefully...
Posted : 21/08/2015 3:18 pm
Ok but the new STX has all the damping setting adjustable externally no?
Whaddya reckon I should get - assuming I want something reliable as well as good - monarch or new STX? I'm wary of first generation products...
Posted : 21/08/2015 3:21 pm
I have no idea, I've not ridden a monarch equipped bike or a STX (has anyone outside the development program?).
I doubt it'll be bad, it's still using the same basic design as any other shock, and it's still made by Ohlins who undoubtedly know what they're doing. On the other hand there can't be much doubt it's a cheaper shock than anything else they've made or licensed, and if it was as good, why did they make the CCDB and TTX? But maybe they're right, maybe an enduro bike isn't enough to really notice the difference between a well made and well set-up TTX and STX?
Posted : 21/08/2015 3:30 pm
Great info here. Thanks
Posted : 21/08/2015 5:08 pm
[quote="Northwind"]It's not a guarantee of quality, that name, they could dip a jobby in gold paint and people'd bolt them to their GSXRs.
Only if the bolts are anodised blue though!
Posted : 21/08/2015 5:34 pm
I'm expecting a serious breach of some Strava times once the believers drop their cash....
Posted : 21/08/2015 5:58 pm
Fox X2 for the same price? I know which one I'll be getting, it won't need a special order from Italy either...
Posted : 21/08/2015 7:20 pm
We've been making some custom bushes for the Ohlins at work.
Posted : 22/08/2015 6:11 pm
I can confirm it looks very nice up close and is relatively light, wasn't attached to anything so cant comment on use yet...
Posted : 22/08/2015 6:16 pm
But you can't get fox X2 to fit enduro though right?
hadge does that mean you could make a spherical bush for the stx?
Posted : 22/08/2015 8:39 pm
Yes you can, just not as a member of the public at the moment.
Posted : 23/08/2015 1:11 am
