"New greaseles...
[Closed] "New greaseless bearings"
9 Users
http://singletrackmag.com/wp-content/uploads/2015/05/new-greaseless-bearing-design-could-keep-you-rolling-further/
Apparently this is a good thing...
...except that grease provides another function in keeping water away from bearings & bearing surfaces...so bearings will die more quickly without grease.
Posted : 22/05/2015 3:46 pm
I'm not saying it can't possibly work, these things are counterintuitive. But it sounds like the sort of thing you can have work in a lab, but dies instantly in use, surely any wear will make it useless? And then, as you say, lose all the other functions of grease- water proofing, dirt screening/collection etc.
I propose MAGNABALLS. Magnetise the bearings, but reverse the polarity of every second bearing so they repel each other.
Posted : 22/05/2015 3:56 pm
 LoCo
Even with grease added I'd guess they would still be more free running than a standard bearing, either that or they could add some good sealing, but again this would add to the free running ness (not a word 😉 )
MAGNABALLS
These would need to be made of unobtaium obviously 😉
Posted : 22/05/2015 3:57 pm
or,
...except that grease provides another function of keeping water trapped in with bearings & bearing surfaces...so bearings will die more quickly with grease.
Posted : 22/05/2015 3:59 pm
Coil hub (would require power) as found in turbocor refrigeration compressors (oil less). The shaft "floats".
http://www.turbocor.com/productinformation.php
Posted : 22/05/2015 4:02 pm
qwerty - Member
or,
So seals are bad and grease is bad? 🙄
Posted : 22/05/2015 4:11 pm
Shame the demo wasn't done with a load applied.
Might work in some applications but I don't see them being much use on a bike. It's always contamination that kills my bearings.
Posted : 22/05/2015 4:14 pm
under load the notches will cause them to self destruct in record time
Posted : 22/05/2015 4:23 pm
 AD
On the other hand I think these might have a use... http://www.skf.com/uk/products/bearings-units-housings/engineered-products/bearings-with-solid-oil/index.html
We use these at work and they've been surprisingly good (so far).
Having said that I ride a Turner so don't have a problem... 🙂
Posted : 22/05/2015 5:25 pm
I personally think it looks awesome, and if not perfect, a definite step in the right direction!
Posted : 22/05/2015 5:44 pm
