New Fork - LBS reco...
[Closed] New Fork - LBS recommending Fox or RockShox
9 Users
In the market for a new 120mm travel fork, can be 9mm QR or 15mm axle.
Ideally good small bump sensitivity and longevity!
LBS are recommending:
Fox Float 120mm (open bath NOT FIT) at £540
or
Rock Shox Reba RL 15mm axle @ £399
Current for is 8 year old Fox Talas which was OK but not great re: small bumps.
Anything else I should REALLY consider at the £500 mark?
Posted : 02/04/2013 4:09 pm
I would buy the Reba from Merlin for £100 less 🙂 Or these and space them down. http://www.jejamescycles.co.uk/fox-racing-shox-32-float-150-evo-rl-qr15-white-tapered-id74199.html?gclid=CPz_oeWwrLYCFaHHtAodJlUAcw
Posted : 02/04/2013 4:14 pm
Then take it to the shop to get it fitted or to borrow their tools. Shops love that, so they do 😉
Posted : 02/04/2013 4:17 pm
nmd: I saw this earlier and I'm guessing these are the forks my LBS are talking about (based on their vague description):
[url= http://www.merlincycles.com/bike-shop/frame-forks/forks-shocks/rockshox-suspension-forks/rockshox-reba-rlt-forks-2013.html ]Merlin link[/url]
I'm guessing the performance of these will exceed my 8 year old Fox forks (especially as their knackered!)
Posted : 02/04/2013 4:18 pm
Fitting a fork is no big deal to me, cutting the steerer is the only critical bit!
Posted : 02/04/2013 4:19 pm
The Reba will be really nice, that'd get my money now that it's Solo Air again
Posted : 02/04/2013 4:20 pm
nmdbasetherevenge how dificult would it be to reduce these down to 120mm travel? What about warranty does it void it if I change the travel?
Posted : 02/04/2013 4:22 pm
Yeah I'd go for the Reba even though I did like my only pair of Fox forks.
These are the ones I meant [url= http://www.merlincycles.com/bike-shop/frame-forks/forks-shocks/rockshox-suspension-forks/2012-rockshox-reba-rl-forks.html ]Here[/url]
Posted : 02/04/2013 4:23 pm
It's easy and it won't affect the warranty. Look on the Fox site for instructions.
Posted : 02/04/2013 4:24 pm
 br
If buying a new set, get a maxle/bolt-thru etc.
What about Magura, I've a 140mm Thor and it works well - very stiff.
Posted : 02/04/2013 4:25 pm
New forks = Merlin!! I would go Rockshox these days - much less servicing required than Fox
Posted : 02/04/2013 4:29 pm
Don't forget to pay them in biscuits.
Oh and tell them you're an engineer if they Whinge
You'll soon have them eating out of the palm of your hand...
Posted : 02/04/2013 4:36 pm
+1 for the Reba 15mm axle. I have the 2012 version and it has served me well so far.
Posted : 02/04/2013 5:38 pm
Last time I fitted forks I used a wide gauge pipe cutter rather than a saw. Very neat, didn't even need to file it to round off the edges. £5 from B&Q.
Posted : 02/04/2013 5:49 pm
Good advice, id go for the Rockshox..
Posted : 02/04/2013 6:12 pm
Thanks all I'm going to go for the Rockshox and will use seavers tip above! Cheers!
Posted : 03/04/2013 1:55 pm
