Do you think I'd get away with this? - a to c is 532mm, currently run 140mm Rev's at 518mm
probably pushing it but doable
I find it hard to keep the front down on steep climbs at 140 so 150 would be worse. Can you get a 140 spring unit for the pikes?
It'll possibly invalidate your warranty also - as I think they are only rated at 140mmm
As above. I think it says on yeti warranty only up to 140mm.
Looks like you need a new sb66 😉
Might be worse than you think too if all this 'rides high' malarky is true.
pretty sure warranty is up to 150mm but I think it's out of warranty anyway
I wouldnt think twice about it. Get them on.
yeah, just run a wee bit more sag. if the front end wanders, shorter stem.
STW had a long term alloy 5 with 150mm forks, but being DT I imagine they'd be shorter A2C
STW had a long term alloy 5 with 150mm forks, but being DT I imagine they[s]'d be shorter A2C[/s]'re shite
