need to change whee...
[Closed] need to change wheel bearings on dt swiss 240 rear hub - tool needed
8 Users
looks like i need a special tool - a ring nut removal tool.
I've put on ad in wanted but has anyone got the correct tool they can lend me ? Obviously postage and beer money paid.
Posted : 07/03/2013 8:27 pm
You only need the tool for the centremost bearing, which very rarely needs replaced- sure it needs done? All the other ones are blunt instrument jobs.
Posted : 07/03/2013 8:28 pm
I've got the others out but the bearing in question is seized solid. Can't think of a way to bodge it either.
Posted : 07/03/2013 8:33 pm
there is a specific vice-tool which sits inside the ring drive and undoes with leverage from the wheel.
good bike shops should have them.
where are you in the uk?
Posted : 07/03/2013 9:18 pm
I have two! Where are you? email me, address is in my profile.
Posted : 07/03/2013 10:50 pm
Ambrose ygm
Posted : 08/03/2013 12:00 am
to remove - old 20mm axle (or similar shaped.....thing) + hammer
to install - some threaded bar + selection of different sized washers and nuts + the old bearings + a spanner
Posted : 08/03/2013 9:59 am
 jimw
Ndthornton
Your advice would lead to a wrecked hub in this case. As stated above, the DT Swiss star ratchet system means the centre bearing can only be removed with the correct tool, which removes a steel' ring nut' . This sandwiches the inner bearing between the hub flange and the nut, which the OP knows. You can buy these from ebay for about £20
Posted : 08/03/2013 10:06 am
Ah - Iv never done DT Swiss to be fair
Posted : 08/03/2013 10:27 am
No mail as yet- hearne_ogwen52athotmaildotcom
Posted : 08/03/2013 3:32 pm
I've sent you an email today about the hub tool . Can you get back to me as soon as possible. Thanks.
Posted : 17/03/2013 11:45 am
LBS only charges a tenner labour to replace hub bearings. Is diy really worth it in this case?
Posted : 17/03/2013 1:04 pm
