Need help finding g...
[Closed] Need help finding geometry chart for 2010 Turner 5 spot.
2 Users
As title really.
I can't seem to be able to find the geometry chart for the 2010 Turner 5 spot.
I can find the 09 and 11 models but not the 10.
Any help would be great.
Steve
Posted : 16/05/2015 8:13 am
This should have the info you require AFAIK the 2010 was basically the same as 2009 but with the revised seat tube gusset ( burrito v taco )
The 44 mm head tube and slightly slacker head angle was on the 2011 frames.
They also ran the rear mech cable through a hole in the rear triangle in 10 or 11 can't remember when it was introduced. The 2009 rear triangle had it cable tied to the side. Wasn't a problem really.
Bit of a turner geek here 🙂
Edit didn't you sell yours?
Posted : 16/05/2015 8:33 am
Yep sold mine.
Just wanted to compare geometry.
I believe the 10 was longer than the 09 but shorter than the 11.
Posted : 16/05/2015 8:39 am
Longer where? Top tube?
I don't think so, could be wrong. Think they only made very minor changes.
I went from a 2009 to a 2011 both in medium. They were very similar.
Posted : 16/05/2015 8:45 am
Its alright Ive found it.
cheers
Steve
Posted : 16/05/2015 10:06 am
Was there much difference in length?
Posted : 16/05/2015 10:17 am
Not really to be honest.
Suprised at how short the reach is though !
Posted : 16/05/2015 10:40 am
I think turner used to recommend a 90 mm stem which wasn't unusual for the usa. Always ran mine with a 75 mm stem on a medium. Tried a large frame with a 50mm stem could have riden either really I'm 5'8.
Had a 2012 version with 150 pikes, that was a superb trail bike. On a Burner now 🙂
Posted : 16/05/2015 10:58 am
