NDB, the Raspberry ...
[Closed] NDB, the Raspberry mullet. ! Specialized Status 140
17 Users
https://www.rutlandcycling.com/bikes/mountain-bikes/trail-and-enduro-full-suspension/specialized-status-140-2022-aluminium-full-suspension-mtb-satin-rasberry-cast-umber/93722-7104.html?gclid=Cj0KCQiAu62QBhC7ARIsALXijXTRIi68a96MwFYC7bS4cWEks2GImlZ8qPdRoJhf3kAJMFxcE02bEA0aAlN5EALw_wcB
After a discussion and an email today, i went bonkers and bought this.
[url= https://live.staticflickr.com/65535/51883398079_e14b588204_c.jp g" target="_blank">https://live.staticflickr.com/65535/51883398079_e14b588204_c.jp g"/> [/img][/url][url= https://flic.kr/p/2n3KYEc ]specialized-status-160-2021-enduro-all-mountain-93720-52-93720-53-3-38259[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
I've been debating one for a while, so thought "why not".....
I fancied trying the mullet thing, along with wanting a Specialized and loved the shape, colour and geometry of the Status.... So why not.. what's the worst that can happen lol. I used the chat online on Rutland and was met with "we only have 1 left in that size, it's in the MK store"... If you want it now i can lower the price a bit..
I replied with "can you throw in a set of pedals too?" he said yes and that was that..
Arrives Tues next week.
Frame - M5 alloy chassis and rear-end, Mixed wheel Trail Geometry, threaded BB,12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm of travel
Fork - FOX FLOAT 36 Rhythm, GRIP damper, two position Sweep adjustment, 15x110mm QR axle, 44mm offset, 140mm of travel
Shock - FOX FLOAT X Performance, Rx Trail Tune, EVOL Air sleeve, 2-position lever w/ LSR adjustment, 210x52.5mm
Number of Gears - 12-speed
Shifters - SRAM NX Eagle, trigger, 12-speed
Chainset - SRAM NX Eagle, DUB, 170mm
Chainrings - 32T
Cassette - SRAM NX Eagle PG-1230, 12-speed, 11-50t
Chain - SRAM NX Eagle, 12-speed
Rear Derailleur - SRAM NX Eagle, 12-speed
Bottom Bracket - SRAM DUB, BSA 73mm, threaded
Rims - Specialized 29, hookless alloy, 30mm inner width, tubeless ready
Front Hub - Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Rear Hub - Alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
Front Tyre - Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
Rear Tyre - Butcher, GRID TRAIL casing, GRIPTON® compound, 27.5x2.3"
Front Brake - SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Rear Brake - SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Handlebars - Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm width
Grips - Deity, Knuckleduster, Black
Stem - Alloy Trail Stem, 35mm bar bore
Saddle - Body Geometry Bridge Comp, hollow Cr-Mo rails, 143mm
Seatpost - X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9mm, S2: 125mm, S3/S4: 150mm, S5: 170mm
Post Clamp - Alloy, 38.6mm
Posted : 15/02/2022 10:06 am
N+1 I hope?
Posted : 15/02/2022 10:10 am
Dunno yet fella... I've no particular reason to sell the G-170 but i'm not a massive fan of keeping things and not using.... but it could well be useful as a race spare in case we have any issues in the lead up to an event, especially as i've got a spring for the coil that suits both mine and his bike.
I generally don't keep things though, so, we'll see.
Posted : 15/02/2022 10:13 am
Nice. Will you be riding it on Sunday?
Posted : 15/02/2022 10:19 am
Nice!
I had the 160mm version for 6 months or so (was a fill in bike whilst waiting for a warranty replacement on my Norco Optic). I really enjoyed it. Did various rides on it, Innerleithan/Golfie, southern enduro milland, BPW, local bimbles and i even did the SDW on it.
If i ever needed a park bike, i wouldnt hesitate to buy one again.
Is there a reason you went with the 140mm version? I guess the 160mm would be too similar to the Whyte?
A little heavy, but a solid bit of kit. Enjoy!
Posted : 15/02/2022 10:20 am
Fraid not, doesn't arrive till Tues and wasn't able to collect in store..
TBH i think at times on the G170 i'm a little in the 'overbiked' sort of thing and was thinking i can still get down the stuff i need on the shorter travel bike but with the hope of it being a little faster on the non-bonkers stuff. The weight, yeah i get you, but there's a budget i'm comfortable with and due to lack of stock my options were slightly limited on what i could or couldn't find. I did dabble in my brain with the Whyte T140, but i have to say i really like the looks of the Status and not the T140. A TREK remedy would have been hard in the debate too but finding one wasn't as simple.
Posted : 15/02/2022 10:24 am
fair play mate.
I reckon the 140 will be a ripper. a bit more nimble maybe than the 160mm and enough travel to keep things interesting.
I found the mullet/short rear end great for getting round tight switchbacks etc.
Dang.... makes me want another one now!
Posted : 15/02/2022 10:27 am
Keep the G170 for race, uplift and Alps duties? I did something similar when I got a lucky deal on a 29er hardtail. It's used for tamer stuff with the bigger bike brought out for the bigger trails. Suppose you'll find out in a ride or 2 if the 170 will still be required though
Posted : 15/02/2022 10:33 am
Keep the G170 for race, uplift and Alps duties? I did something similar when I got a lucky deal on a 29er hardtail. It’s used for tamer stuff with the bigger bike brought out for the bigger trails. Suppose you’ll find out in a ride or 2 if the 170 will still be required though
I can't think of any real reason to sell the G170 at the moment, so for Alps i may well take both, just in case we break one. My lad can at a push ride or indeed race the G170 in terms of sizing now, although it would be a bit big for him, he'd still cope well enough to get a result.
Posted : 15/02/2022 10:38 am
Looks nice
Posted : 15/02/2022 12:41 pm
Invisframe kit on the way for it.
Posted : 15/02/2022 12:54 pm
He rode a raaa-spberry mull-et...
Nice, but expect to be replacing that SRAM NX tat rapidly
I'd either sell it straight away and replace with Deore or better or wait until you have to warranty it and do it then
Posted : 15/02/2022 12:56 pm
I’d either sell it straight away and replace with Deore or better or wait until you have to warranty it and do it then
Yeah there's that and there's the DUB cranks/BB... we'll see how things last and i'll make some decisions over time. As with all bikes, they evolve, change, modify, so it's no biggy.
Posted : 15/02/2022 1:27 pm
Still reckon it'll be an awesome bike, just think NX isn't up to the abuse the rest of it is built for
Posted : 15/02/2022 1:36 pm
Thank you... just got to wait until next Tues now.... well, maybe actually next Fri as i need to fit the invisiframe kit before taking it out.
Posted : 15/02/2022 1:38 pm
 Olly
Lovely. Current specializeds look very clean.
Cant decide if having different sized wheels would annoy me, as i tend to put the front on the back and replace the front.
The theoretical advantages are solid though.
Posted : 15/02/2022 1:41 pm
I'd be very tempted to send the Invisiframe kit to Rutland and pay them to fit it, make new bike day even nicer when all you have to do is set it up and ride
NAh, Mrs Weeksy will enjoy that
In honesty, it arrives on Tues next week and she's away Tues and Wed with the boy for half term, so i'll have 48 hours at home alone to wangle it about and fit it over a few beers and a bit of music.
Posted : 15/02/2022 1:43 pm
I've been very 29er curious in recent months and even considered swapping the wheels on the G-170 to 29er for some testing, but i don't think the front had clearance, so shelved it as a plan. It'll be going to FoD and BPW etc for back to back testing with the G-170 which will give me more of an indication whether i'll run it 100% of the time or keep the G-170 for the big days. I'm expecting i'll run this on 100% though if it rides how i hope it does.
Posted : 15/02/2022 1:45 pm
Good purchase that I reckon @weeksy 👌
If they sold it frame only I would have been seriously considering the status 140 to replace the Bird Aether 7. But only full builds - I did check with Certini.
I think the Status will be more capable than the g170 tbh - it’s a much better shape frame and got decent geometry. When I had a quick go back to back between my sentinel and your g170 I’d say I felt ‘in’ my bike but on top of the g170.
On the NX front I’d run it until the rear mech expires and just replace it with a GX one or Shimano XT. The cassette is heavy but solid and a decent 11-50 range. I don’t think there’s too much wrong with the NX shifter.
Posted : 15/02/2022 1:52 pm
its a beefy workhorse alloy bike, let it wear its scars with pride.
I'd be taking the full NX off unused and selling if its going to be your everyday bike that gets some milage. If it was a park/uplift/pushup/messabout bike only I wouldnt be so concerned.
Maybe even swap it to the whyte if that is going to become your "DH" bike.
Posted : 15/02/2022 2:00 pm
I’d be taking the full NX off unused and selling if its going to be your everyday bike that gets some milage. If it was a park/uplift/pushup/messabout bike only I wouldnt be so concerned.
Maybe even swap it to the whyte if that is going to become your “DH” bike.
The G-170 has 175mm cranks and the Status has 170mm which ideally i'd like to run. So i won't bother swapping bits off it at the moment
Posted : 15/02/2022 2:04 pm
With the fun stuff I’ve had one bb so far on my hardtail. It hasn’t listed brilliantly well - less than a year later and I’ve got a wheels manufacturing dub one to try that cost more than I’d have liked. Will see how that goes.
That said my Bird Aeris 145LT had an NX crank with dub bb and that was flying along fine for over a year and then went on my nephew’s bike and it’s still going.
So maybe it’s a bit pot luck on bb alignment / facing etc 🤷‍♂️
Posted : 15/02/2022 2:13 pm
I've got the 160 version.
The NX stuff went as soon as I got a SRAM freehub from Specialized. Went for 165mm cranks.
The bars went shortly afterwards....I bent then round my thigh 🙄.
The rims were a bit soft as well.
The shock just didn't work for me, I could not get it set up well, so went all in and bought an EXT Storia.
It is awful on anything flat or traversy, weighs a metric tonne but is ace on anything pointing down.
Posted : 15/02/2022 2:33 pm
LOL great sale pitch mate 🙂
I'm guessing the 140 can't pedal worse than the G170... but time will find out that answer of course.
Posted : 15/02/2022 2:48 pm
I’ve got the 160 version.
The bars went shortly afterwards….I bent then round my thigh 🙄.
The shock just didn’t work for me, I could not get it set up well, so went all in and bought an EXT Storia.
Wow, talking it up!
NX is defo use until it breaks - it works for a lot of people for a while. It’s not as bad as SX with the plastic mech that just snaps off.
Bars - assume it’s just an alloy bar - how do you mean you bent it round your thigh?
I’ve got a float x performance elite on my sentinel and I think it’s pretty good now I’ve got back used to an air shock. It does have a lsc adjustment dial that the one on the status hasn’t though.
Posted : 15/02/2022 3:05 pm
Nice looking bicycle there @weeksy. I do love a good Spesh and this one is very pleasing on the eye. Quite like the green version too.
Posted : 15/02/2022 3:10 pm
We’ll done. NBD is my favourite day and if I was looking for a new bike that would be on my list.
You should have no problems fitting the Invisframe to a new bike. It’s dead simple. You’d have to be fairly hamfisted to coconut up.
Enjoy blasting it around.
Posted : 15/02/2022 3:33 pm
NDB?
Seriously though that looks excellent. Had my mob nicked a couple of weeks back so looking for something now and that could fit the bill.
Posted : 15/02/2022 3:37 pm
yeah New Dike Bay.... errrrrm.
Posted : 15/02/2022 3:48 pm
Very Nice!
Had half an eye on one of these too, so would be very interested in your thoughts after a few weeks of riding please!
Posted : 15/02/2022 4:17 pm
If anyone is looking for one the Specialized Concept store in Bristol had a few Status’ on display on the weekend just gone. Not sure if they were 140s or 160s though. Seemed to have a lot of stock in there - some stump jumpers / stumpie Evo’s etc too.
Posted : 15/02/2022 4:20 pm
some stump jumpers
Mmmmm... Stumpy.... Mmmmm
Must resist 🤣
Posted : 15/02/2022 4:22 pm
Mmmmm… Stumpy…. Mmmmm
Must resist
I considered a Stumpy, they had a very powder blue version about, but the price of the status and the spec made it more 'right' for my budget really.
Posted : 15/02/2022 4:23 pm
I think I kinda focused on the stuff I didn't like about the 160 😳😳.
I'm sure that the 140 will work better as an all-round bike.
I'm still getting personal bests on some climbs so it can obviously go up a hill.
I used to be more of a plower on a bike but this one has encouraged me to hop and jump stuff. It is a lot of fun to ride when it is pointing down.
Posted : 15/02/2022 4:33 pm
Am I the only person wondering what pedals?
Also NDB clearly meant "Next Tuesday Brings" but your acronym generator is set to German.
Posted : 15/02/2022 4:44 pm
That's a lovely looking bike, nicer to my eyes than the Enduro / Stumpjumper.
It's a part-time job keeping up with Spesh models, Statuses or Statui? used to be DH bikes that were cheaper than Demos, but now they're Enduro (the niche) / Trail bikes that are cheaper than Enduro (the model) / Stumpjumper like the old 26" Pitch FS bike. the Pitch HT replaced the Rockhopper as the entry level HT, but now they're Rockhoppers again,
Posted : 15/02/2022 4:46 pm
A mate has that baby blue carbon stumpie Evo. It’s nice. Similar spec I think to the status in terms of shock and fork but maybe a better drivetrain / lighter frame. Showed him a clean pair of wheels on my alloy Sentinel up and down hills though 😎
Posted : 15/02/2022 4:57 pm
Nukeproof neutron.
Posted : 15/02/2022 6:09 pm
Bearings, 6802
Rear shock mount bolt 24Nm
FRont shock mount bolt 10Nm
Front 3bar 20Nm
mid 3 bar 16Nm
Back 3 bat 16Nm
Rear swingarm pivot 24Nm
Main pivot 20Nm
14 x 6802s that's a LOT of bearings lol.... fortunately i have all the correct tools... But i'm pretty sure i don't have 14 spare bearings at the moment hahahaha. I do have 4-6 though as many of them are found on the Sworks.... but it looks like i'll need to stock up on 6802s for the future.
Fortunately the manual for the Status is excellent, even showing the flipchip configuration
[url= https://live.staticflickr.com/65535/51884845338_bf5461c8bf_c.jp g" target="_blank">https://live.staticflickr.com/65535/51884845338_bf5461c8bf_c.jp g"/> [/img][/url][url= https://flic.kr/p/2n3ToSW ]flipchip[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Posted : 16/02/2022 6:44 am
Further reading on the Status.
https://www.mtbr.com/threads/2021-specialized-status.1145425/
The bearings are a doddle to change 👍
Posted : 16/02/2022 9:02 am
Yeah the bearings/bolts/spacers are the same as our Sworks, so is the mech hanger too which is nice. The bearings on the Sworks have been pretty good, but when needing swapping are not a hard fit like some and go in easy and come out easy, so i'm all good with that.
Posted : 16/02/2022 9:05 am
Apparently due to issues this has had to be cancelled....
Moving swiftly on 🙂
Posted : 16/02/2022 10:24 am
The Status is no longer in stock?
Posted : 16/02/2022 10:32 am
