NBD!! And Cube drop...
[Closed] NBD!! And Cube dropper post has sinking feeling
5 Users
Hi folks.
Picked up my new bike on Saturday. First new bike in ten years so super stoked.
Will take some photos and do a wee review at the weekend.
In the mean time, I have an issue with the dropper. It drops. When I am peddling along. On its own. If I push the leaver up the way after I have released it the post stays up a bit better but still gives.
So, does the barrel adjuster take care of this or will it be needing returned?
Cheers,
Garry
Posted : 14/11/2016 7:12 pm
Sound like it's just been set up badly....
Posted : 14/11/2016 7:23 pm
Sounds like a cable is too tight, if there is adjustment in the barrel adjuster then just slacken the cable off a bit.
It's just not fully releasing the little lever at the bottom of the post, a bit less cable tension and it should be fine. Have you adjusted the saddle height since you picked it up?
Posted : 14/11/2016 7:33 pm
Hiya. Thanks for the feedback.
Yeah had raised it a touch. However, had another look tonight including playing with the barrel adjuster. Noticed a fair bit of grease leaking out from the seal...that'll be the problem then!! Back to the shop with it!
Posted : 14/11/2016 10:51 pm
not nessacerily, grease could just be internal grease coming out on early use. Sounds more like cable which is set up but the nice thing about a new bike is you can go back and get it sorted, whats the post?
Posted : 15/11/2016 5:42 am
Hi. The post is an RFR. I think they make them for Cube but I could be wrong. I'll phone Dales again today to see what they think is the best course of action. I played around with cable tension last night and slackened it right off but it just kept dropping every time I sat on it.
Posted : 15/11/2016 6:57 am
RFR is just Cube's own brand for parts. Is it internally routed or external?
Posted : 15/11/2016 7:05 am
