does anyone know where the reaper trail is , seen it on you tube but cant see it on any trail map . Also is it worth a trip .
I’ve no idea about ‘the reaper’ it’s unoffical it seems.
I really like the Summit trial, it’s worth a few hours drive for me now and again.
It's not on the map - it's on the hillside opposite the legburner climb. I think it starts somewhere near the top of Mark of Zorro in a 'follow your nose' kind of way.
I would've thought there was a Strava segment you could use to get yourself near the start.
A friend emailed this to me, he has done it loads of times.
<span style="font-size: 0.8rem;">It's after the gate to the doubletrack climb, you'll notice a sign on the left, right before it starts to get good, do the summit and you'll see a sign on the left with a slight footpath, just follow that, hop the fence and enjoy, you'll finish at the bottom of leg Burner, I hope that makes sense haha</span>
Hopefully it makes sense to you. Pretty sure i can work it out from memory, been 6 years or so since i last went there.
