My rear SLX brake i...
[Closed] My rear SLX brake isn't working very well
6 Users
 FOG
It is the oldder pre 10sp brake. There is no trace of sponginess, I have put in new pads, cleaned the disc with brake cleaner, fiddled with the reach adjuster to no avail. When you grip the lever it feels fine, it just doesn't stop very well. One thing that did occur was the disc is three years old but it looks straight and the surface looks ok to a normal eyeball.
Suggestions appreciated.
Posted : 11/10/2012 12:04 pm
Is it aligned centrally to the disc?
Might be worth doing a re-bleed even though there is no sponginess.
Posted : 11/10/2012 12:09 pm
Are both pistons pulling? (tbh, an SLX ought to still give decent performance even with one piston seized like a boss, but still worth checking)
Posted : 11/10/2012 12:18 pm
 FOG
Both pistons seem to be working. I did the 'rub with mineral oil' thing and although not quite simultaneous both pistons moved ok.
I have loosened the caliper bolts and re-aligned the caliper but doesn't seem to make any difference. I think a bleed and a different disc are the next moves
Posted : 11/10/2012 12:22 pm
Have you bedded in the new pads?
Posted : 11/10/2012 12:23 pm
Move it to the front, see what happens.
Posted : 11/10/2012 12:24 pm
If the lever is firm but there is no power then a bleed wouldn't be the first thing on my list, it sounds more like a rotor / pad issue. What did you clean the disc with? My money would be on some kind of contamination issue.
Posted : 11/10/2012 12:42 pm
Pull the lever harder?
Posted : 11/10/2012 2:04 pm
 FOG
never thought of that
Posted : 11/10/2012 5:35 pm
