Anyone know if this is possible?
I want to drop from 105mm to 85mm.
Failing that anyone want to swap some 2005 MX Pro's for either something more modern/shorter or some 85mm equivalents?
Have a look in the top of the forks, if theres a 20mm plastic spacer in each leg then you should be able to do it (it may be above or below the spring)
If it's got an ETA lever then no, not without replacement internal's
It's ETA 🙁
Air spring and rebound adjuster on one leg, ETA on the other.
An email I got from Windwave when I asked about this: [i]to reduce the travel of the MX Pro to 80mm will require a new shorter travel ETA cartridge + spacers for the non ETA side, [/i]
