I was quite fancying a one-up that fits in the headtube - but didn't fancy the extra cost of tool you need to buy to remove the star nut & use just once.
Are there any other similar ones out there?
EDC Lite? Specialized and Granite-design, also a few bar end options (Wolf-tooth I think)
Topeak do a stash range too
Oooh like the look of the EDC lite thanks
Have a search on bikepacking.com, they did a round up of such tools/setups. https://bikepacking.com/?s=multi-tools
That EDC lite look brilliant, almost exactly the same as the Granite one but uses the steerer nut.
You can put the one up inside a pump if that might work for you? I've just done it and it's very slick.
James
Where are you @PrinceJohn? I have the fitting tool and the EDC is a great bit of kit. The oil slick top cap also looks the nuts 👌
I like my wolftooth encase tool.
I sold a OneUp EDC and replaced it with this https://www.giant-bicycles.com/int/clutch-crank-core-storage-2020 - that freed up my steerer tube for a pump & puncture repair kit https://singletrackmag.com/forum/topic/diy-steerer-tube-stash-pump/#post-11668829
