Mudhugger Velcro ha...
Mudhugger Velcro hack
8 Users
Like my Mudhugger, like the use of zipties less so.
I had some Polaris Velcro straps that looked likely, so did a bit of experimenting.
Measured width of straps and drilled some holes in a line with a 2.5mm bit.
Finished off the slots with a small hacksaw blade and a small file.
For the others I used a coping saw to make indents of the correct size.
Fitted the straps nice and tight (and used one zip-tie per side just in case 😉)
Rode 45km mostly off-road and it didn't move a mm. Jobs a good un, and makes much more sense than loads of zip-ties.
Posted : 04/12/2022 7:48 pm
I widened some of the cable tie slots on mine to use velcro, same reasons. But I couldn't get it that tight, and some of the slots split, so went back to cable ties. This looks better.
Posted : 04/12/2022 8:56 pm
Why not just use re useable cable ties?
Posted : 04/12/2022 9:02 pm
i just enlarged the existing holes for velcro instead of starting another one
the V2 mudhugger is velcro fastening now
Posted : 04/12/2022 9:09 pm
Because I already had the velcro straps?
I would've had to buy reusable zip-ties, and normally they're wider, so would probably need to enlarge the holes.
In my head having the holes further up meant more overlap/length for the velcro, so probably more secure?
Posted : 04/12/2022 9:10 pm
Got a V2 with the velcro straps. Doesn't seem quite as secure as zip ties.
Posted : 04/12/2022 9:23 pm
All cable ties are reusable 😉
I use velcro wherever possible for this though, although it does wear out from the mud eventually.
Posted : 05/12/2022 3:27 am
Ha, yes, up to a point. Probably get 3-4 goes on them before it doesn't work properly.
Posted : 05/12/2022 6:49 am
Mudhuggers are ace.
But what's with this latest thing of people not liking zip-ties?
Looks? Not knowing how to use them correctly? Environment? Cost?
Posted : 05/12/2022 8:10 am
But what’s with this latest thing of people not liking zip-ties?
From my perspective the problem of them "cutting" into the frame unless they are adequately protected,
Posted : 05/12/2022 8:17 am
Partly environmental - yes, you can potentially re-use zip-ties, but not always, and it's extra plastic waste in the end.
Being able to swap the guard onto another bike much more easily. I have 2 Mudhuggers and 4 bikes they can fit, I'd rather not spend £50 on another 2 mudguards.
Safety - I have a lovely scar on my calf from the end of a zip-tie used to secure a cable outer onto a seat stay. There's plenty of potential for zip-tie based injury from all those used on a Mudhugger.
Posted : 05/12/2022 9:33 am
So I can get the bike in the car without it bending out of shape and swap between bikes quickly
Posted : 05/12/2022 12:06 pm
