Mudguards - this do...
[Closed] Mudguards - this doesn't look right...
19 Users
Just fitted a front mudguard. Most of it is fine except the front bit beyond the fork, but this us the bit I cannot adjust as is is screwed in the the rear of the fork and cannot be adjusted down any further.
Surely it can't be right then the front bit should sit so far above the tyre...?
[URL= http://i1280.photobucket.com/albums/a491/loddrik1/Mobile%20Uploads/0BC0DB3B-0AA9-4258-8BDA-94DD8171EFD1_zpsdl6buv6b.jp g" target="_blank">http://i1280.photobucket.com/albums/a491/loddrik1/Mobile%20Uploads/0BC0DB3B-0AA9-4258-8BDA-94DD8171EFD1_zpsdl6buv6b.jp g"/> [/IMG][/URL]
Posted : 03/02/2015 3:45 pm
looks the wrong
Posted : 03/02/2015 3:47 pm
Is it for a 700c wheel and you are using 26"?
 aP
To make it [i]look[/i] right, you need to make the mudguard have the same distance to the tyre all the way round - which you can't do as you've cut the stays already. Or get a different fitting to drop the front end at the fork.
Posted : 03/02/2015 3:49 pm
It's not the rear guard is it?
can it not be adjusted on the supports to even the gap out over the whole wheel?
That is a cyclocross fork - those are road bike guards. Crown to axle length are different to give more mud clearance. You need a longer bracket. It might have to be DIY job. Also, not sure from picture but the clearance looks a bit iffy at the bottom too - I'd make it a bit bigger - muddy road crap will soon fill up the gap between the two.
edit - looking again even for a cyclocross bike the distance from top of the tyre to the crown seems big - what size wheels are they?
Posted : 03/02/2015 3:52 pm
 chip
Does it make any difference if fitted to the front of the fork.
Posted : 03/02/2015 3:53 pm
I made up a small bracket to drop the effective fork crown height when I fitted mudguards to a rigid mtb fork and then bolted the 'guard to the new bracket.
Posted : 03/02/2015 3:56 pm
In the past, I've made an 'mount extension' out of an old reflector bracket to lower the mudguards closer to the wheel under the fork crown.
Posted : 03/02/2015 3:58 pm
You need a bit of meccano! That what I used to bridge the gap between the steerer and the guard bracket.
Posted : 03/02/2015 4:12 pm
See that bolt halfway up the fork leg? If you attach the stays there instead of at the hub,do you get the clearance to even it up with the top? I'd be looking for as much clearance as practical on anything headed offroad.
Posted : 03/02/2015 4:18 pm
Good idea to use the lowrider bosses
Posted : 03/02/2015 4:39 pm
You have a few mill on the stays to play with as well move them right out and it will even the gap out
Posted : 03/02/2015 4:40 pm
is the disc calliper obstructing the arm of the mudguards causing it to bend to one side?
Posted : 03/02/2015 4:43 pm
 ton
who give's a monkey's arse if it looks right or not.
it is there to keep muck and shyte off you, not to look pretty.
There is a lot of twiddle being spouted on here dressed up as advice. You have correctly identified the problem that you cannot lower the bracket any more, one poster has correctly identified that you need to get it lower and this will likely require a bit of DIY to get low enough. Easily achieved with a bit of metal plate a drill and a saw. Otherwise, the stays are fitted correctly.
Posted : 03/02/2015 4:48 pm
I just mounted mine to the low rider bosses on the middle of the fork , works a treat 🙂
My arkose fork only has mounting holes half way up the leg, weren't sure if they were for mudguards or low rider mounts , either way it works
Posted : 03/02/2015 5:25 pm
This is your answer
Posted : 03/02/2015 5:29 pm
Looks like you could gain an extra 10-12mm if you lost the plastic end caps off the stays which would help matters
Posted : 03/02/2015 5:31 pm
