for the first time ever
it's 12 speed with absolute black oval chain ring, chain is well within spec. When I cleaned everything up with a clump of grass it was okay again
time for a chain guide?
any ideas
thanks
if it's an NX mech it's probably that, they are nearly as bad as apex
nope - X01
I run 1x11 on both my bikes, clutch mechs and n/w chainrings, but still run a chain guide. It stops things going wrong if things are a bit worn, but it does allow me to neglect the drivetrain too much sometimes.
This chainguide is excellent.
https://www.chainreactioncycles.com/oneup-components-chain-guide/rp-prod141767
Check you have not bent a tooth, a mm or so will start throwing the chain especially towards the end of cassette range.
That said I usually run a chain guide, though getting one to fit an oval would be more difficult.
Most likely just a bit of mud or grease gumming up the N/W tooth profile, the chain will ride off with a pretty minimal amount of gunge on there clutch mech or not...
Some chainrings don't shed mud well, especially if there is a 'shelf' under the narrow tooth. Some AB chainrings didn't use to play well with KMC chains. This may be fixed now but for a while AB were blaming KMC for producing out-of-spec chains, although other chainrings were fine with them. Is the chainring worn?
Anyway - lots of potential factors. So yes, run a top guide to mitigate all this.
I've found chain guides worse than useless when it comes to the 'muddy ride' type of chain drop - issue is often the rear mech being clogged and the chain drops off the bottom of the ring and then, if you have a chain guide, it just jams in that instead of falling right off.
