MRP XCG good idea o...
[Closed] MRP XCG good idea or not?
5 Users
As above, are these any good? Anyone using one?
I've 1 bike I use for everything so like the 3 rings at the front but like the idea of some protection.
Seems like an obvious design, why's there only 1 company making them?
Posted : 16/04/2011 3:07 pm
does your chain come of regular or do you damage chain rings all the time ? if not why do you need one ! 😆
Posted : 16/04/2011 3:24 pm
I would check that your frame is designed to take a taco guard first: Not all of them are and using one can damage the frame and invalidate the warranty, if the frame isn't designed to take one.
Posted : 16/04/2011 3:27 pm
Waiting on new SLX chainset and not keen to use the big ring as a bash guard! Had a couple of rides recently were the old chainset took a fair bit a abuse, its more rack and logs than loosing the chain.
Frame is DMR Trailstar, I'm not even slightly worried about warranty! ISCG mounts so shouldn't be an issue anyway.
In truth I probably don't need it but its been a quiet day in work and I've had too much time to tempt me 🙄
Posted : 16/04/2011 3:35 pm
Yup had one for a year or so on my Meta 5, BB mount. Plenty of scrapes on it so it's doing it's job, and proper fit and forget item.
Roblane it's not a tensioner just a guard.
Anyone basis for the guard damaging frames mikey74? Been using bash guards in various forms since the mid 90s and never had a problem despite wanging one hard enough to snap a chunk off.
Posted : 16/04/2011 3:43 pm
Only that not all ISCG tabs are designed to take the taco guards. I have been told by the designer that using a taco guard on my Banshee, for example, would invalidate the warranty as the tabs and the surrounding BB shell is not designed to take them.
I am sure loads of people have used them and been fine, and I'm just passing on info. The choice is up to you.
Posted : 16/04/2011 3:53 pm
Fair enough!
Posted : 16/04/2011 3:56 pm
I have them on both my xc bikes, never used to bend chain rings but like being able to smack in to stuff knowing i won't damage anything. Top value for money for me. Both mine are BB mount and have been no problem.
Posted : 16/04/2011 4:04 pm
