MRP Boostinator v H...
[Closed] MRP Boostinator v Hope adapter
5 Users
 Gunz
I've got some new boost forks that I need to fit a non-boost wheel to.  Does anyone have any experience of the two adapters above.  I'm keen on the MRP one as it doesn't need the wheel to be re-dished but they aren't available until the end of the month and I have BPW coming up soon after, don't want to miss using the new forks.
Cheers.
Posted : 23/06/2018 9:50 pm
I've a MRP one for my dtswiss hubs. It's nicely made and I really like that the wheel did not need redishing (meaning I can use the wheels as backup for my other bike).
Posted : 23/06/2018 9:59 pm
The Hope works well, and is a chunk of cash cheaper.
As far as the redish goes, it was a matter of loosen off a full turn on one side and tighten the same on the other. 5 minutes tops. If you needed to use on another bike then just reverse the process.
Posted : 23/06/2018 10:22 pm
Re dishing the wheel is a piece of piss ....
Posted : 23/06/2018 10:23 pm
I've got the Hope adaptor on Hope hubs. Works well, no need for re-dishing or replacing your chainring for a boost one....if that would bother you anyway.
Posted : 23/06/2018 10:52 pm
 Gunz
Cheers all, Hope it is then.
Posted : 23/06/2018 11:56 pm
