MRP 1x chain guide ...
[Closed] MRP 1x chain guide waaaay off help
7 Users
 hora
Ok mounted as per instructions however the thermoplastic guide is circa 5mm out I.e it need to come out to allow the chain to sit without rubbing. Scratching my head here ... Help!
Posted : 20/10/2011 6:49 pm
BB spacers?
Posted : 20/10/2011 7:01 pm
 mboy
What width BB shell?
How many spacers you running?
Chain Device needs to be right next to the BB cup, so if you need to run any spacers, put spacers between BB shell and the chain device.
EDIT: What cranks and chainring you running? Can picture the problem in my head, but if you've got a photo of the problem, post it up too... Might be something very simple that a photo might help with.
Posted : 20/10/2011 7:08 pm
 hora
I need the middle ring nearer to the BB though adding spacers would push both ring and middle ring an equal distance both further outwards
Posted : 20/10/2011 7:09 pm
The 1.X arm should be oriented so the knurled texture around the bottom bracket hole contacts the frame.
[url= http://www.mrpbike.com/pdfs/1.X%20guide.pdf ]instructions online[/url]
mine is next to my frame and replaced 1 spacer on a 68mm BB shell.
so it goes frame, device, 1x2.5mm spacer,then the cranks.. works fine.
Posted : 20/10/2011 7:22 pm
so it goes frame, device, 1x2.5mm spacer,BB cup,then the cranks... edit.
Posted : 20/10/2011 7:40 pm
are you going to break this as well Hora?, as you seem to have a reverse midas effect when it comes to anything to do with bikes or bike maintenance based on your previous posts. 😀
Posted : 20/10/2011 7:43 pm
I had this. Then realised I'd mounted the ring on the outside of the spider. Mount the ring on the inside of the spider??
Posted : 20/10/2011 7:44 pm
Had a similar problem with my eThirteen XCX, got some chainring spacers.
ID and Wheels Manufacturing do various sizes.
Think I got mine from here: http://www.billys.co.uk/english/productresults.php?dept=235&group=D
Posted : 20/10/2011 7:53 pm
