Mounting Reverb 1x ...
[Closed] Mounting Reverb 1x lever on Shimano I-spec II brakes
4 Users
Has anybody done it? Did it work well, any products that can be recommended?
The only thing I've been able to find is  https://www.sjscycles.co.uk/brakes/problem-solvers-mismatch-12-adapters-shimano-ispec-ii-brakes-to-sram-matchmaker-shifters-pair Anybody tried it?
Posted : 10/10/2018 12:40 pm
my Reverb 1x came with a little clamp so you could mount it independently of the brake lever, would that not work or do you want it on the same clamp?
Posted : 10/10/2018 12:50 pm
I'm going to try that but i like the idea of the bars being clean as poss.
There's already so much on there.
Posted : 10/10/2018 1:11 pm
I am using that ProblemSolvers adapter to mount my SRAM shifter to an M8000 brake lever, should work just fine with the Reverb 1x lever as well.
Posted : 10/10/2018 1:14 pm
I have that ProblemSolvers adaptor too - to do that very thing.  Unfortunately I have I-spec 1 levers at the moment...
Posted : 10/10/2018 1:33 pm
