Most important comp...
[Closed] Most important component
23 Users
Assuming that everything is reasonable quality, i.e. it works and doesn't break too often, what do you reckon is the most important big of the bike?
I reckon tyres as they affect so much of how a bike behaves, I probably obsess over them more than anything else (and from the number of "what tyres for?" threads I'm not alone.). Anyone care to argue on a Friday afternoon?
Posted : 22/04/2016 1:22 pm
The rider?
Posted : 22/04/2016 1:28 pm
The beauty of a basic push bike is that there is really no components that are surplus to requirements, therefore your question is void, it's all critical.
Posted : 22/04/2016 1:34 pm
The nut behind the bars
Posted : 22/04/2016 1:38 pm
Critical? Couldn't say. But I do love tyres and wheels for combination of aesthetic and function.
That said, the more I look at rear derailleurs, and how precise and beautifully crafted they are, the more impressed I become.
Posted : 22/04/2016 1:41 pm
Contact points are important, saddle, bars and pedals all make a big difference.
Tyres can make a big difference, crap tyres can make a bike feel very dull, as can crap, heavy wheels.
But then all this is irrelevant if you have a poor frame and forks.
But then, if you can't stop safely it all falls apart anyway, so brakes are pretty damn important too.
You also need to go as well as stop, do a good drivechain can make a bike feel different.
So basically it's all important.
The frame. If that's wrong (or wrong for you at least) then no matter what else you change you will never be fully happy with the bike.
Posted : 22/04/2016 1:42 pm
perchypanther - Member
The rider?
Hmmm, I regard myself as more than a mere component, but I would agree the rider is more important than the tyres (though the tyres are incredibly important).
Posted : 22/04/2016 1:44 pm
If the question is if you could have a base spec bike with one top spec component what would it be? I'd say frame obviously, followed by wheels and tyres. Basic gears and brakes work well these days, forks are pretty decent but non tubeless narrow rimmed heavy wheels and hard compound tyres will ruin a bike
Posted : 22/04/2016 1:45 pm
Brakes, speed without being able to stop in a controlled and safe manor is mighty dangerous, as I found out just before Xmas 2013! 😉
Posted : 22/04/2016 1:46 pm
Its got to be the saddle surely? If you cant get comfy you're never going to enjoy or bond with the bike?
Posted : 22/04/2016 1:49 pm
All my bikes are far greater than the sum of their individual parts.
Posted : 22/04/2016 1:51 pm
chrishc777 - Member
Yeah that's the question I was really meaning. Obviously any one thing being utter crap will make a poor bike. I used to think frames, but they make up so little of the total mass of the bike that overall as long as it's something reasonable and of the type you're after (XC, trail, enduro, DH etc) it's not that important.
Posted : 22/04/2016 2:09 pm
Surely the frame? As above, add-on bits are interchangeable but it's the frame that provides angles and whatnot.
Smart answer, but definitely not the rider as a rider is not part of a bike.
Posted : 22/04/2016 2:21 pm
Chain? without it you're not going too far
Posted : 22/04/2016 2:27 pm
You must be doing it wrong then 😉
Posted : 22/04/2016 2:28 pm
Probably, but rider+bike components needed for biker, not bike.
(Oddly, this is reminiscent of Bruno Latour's philosophical musings about gunmen)
Posted : 22/04/2016 2:39 pm
Probably tyres, because nothing works with bad tyres. Everything else you can ride around as long as it's basically fit.
philjunior - Member
I regard myself as the worst component. Every so often I sell a bike so it can get it upgraded.
Posted : 22/04/2016 3:07 pm
Disagree. You can have a great ride without doing anything muddy, or doing any gnarly downhills. If you aren't doing either of those two things tyres don't make much difference.
Posted : 22/04/2016 3:13 pm
At last weekend's enduro race I was gnarpooned to the max in the hardtail class. I still came second from last. Admittedly the times above me were pretty tight whilst the one person I beat was minutes behind but still, you can't buy speed/skill/balls/fitness, which is annoying. 😉
Posted : 22/04/2016 3:15 pm
Frame, it affects the nature of the bike through geometry. But if you already have the bike then yes, tyres isn't a bad shout. Grip, speed, feel can all be altered with different treads and pressures.
My CX bike changes nature when I go from 28mm slicks to low pressure 32mm mud tyres.
Posted : 22/04/2016 3:36 pm
Most critical is brakes.
Most important is a toss up between front mech and innertubes 😈
Posted : 22/04/2016 3:42 pm
I think tthew nailed it. There's so little (no) redundancy on a bicycle that every component's important.
Saddles are important as without being comfortable you simply won't enjoy the ride. Frames seem like the obvious choice but they can be ruined by shitty suspension or terrible tyres.
Assuming that a frame isn't a component then I'd go for wheels. A light stiff wheel set transforms a bike more than anything else.
Posted : 22/04/2016 4:33 pm
Posted : 22/04/2016 4:34 pm
 botk
there's very little on a bike that could be discarded and still leave the bike functioning. you could at least for a short while live without grips, a seat post and saddle, even brakes (killed a fair few trainers as a kid) but as mentioned pretty much every bit plays its part so whilst some parts may have a greater influence on the riding experience pretty much all are important.
Posted : 22/04/2016 4:50 pm
 Euro
Suspension and tyres. Be it bike, motorbike or a car. If it goes off road then suspension and tyres. Always. And forever. Amen.
Posted : 22/04/2016 5:16 pm
Only less important components are the mechs, cassette, gear cables, big ring and little ring. Everything else is important.
Posted : 22/04/2016 5:25 pm
Errr....wheels?, you're not getting far without 'em
Posted : 22/04/2016 5:26 pm
Seat post bolt.
Posted : 22/04/2016 5:27 pm
