Most hazardous surf...
[Closed] Most hazardous surface other than ice? Stories please.
43 Users
It's been a good while since I've been on anything other than a hybrid or road bike - so heading out to test the new MTB last night was exciting. Spent most of the day fettling, fitting, adjusting, re-indexing gears, tensioning loose spokes, adding lights and saddle etc...
So far so good.
Head off in the dark at a decent pace uphill. Weather warm and drizzling. Will take a while to get to the coastal path and don't have offroad lights fitted so I decide to head to the retail park where it's light and I can do a few more checks and fine adjustments.
Stand up to power down on the pedal and SMACK. I'm on the floor amongst the bike. I see the bike frame on my shin, I lift it, the shape of the frame remains imprinted for a while like a shin half-pipe.
Pride hurts more than the bulbous and blackening shin. I get up and hobble away from staring zombie- people to then learn that about 6" of skin was unzipped at the back of right leg from heel upwards. I've got blood in my shoe and it feels good to be back. Time to re-learn some basics...
[b]Tyres: Conti Barons
Surface: Smooth, flat, wet paving slabs with a fine layer of algae on top.[/b]
Posted : 29/12/2015 9:52 am
Wet chalky rocks and mud on the Ridgeway. Death By Chalk is well named.
Posted : 29/12/2015 9:53 am
Diesel on a damp/wet road.
If you keep your wits about you, you can often smell/see it before it's too late.
Posted : 29/12/2015 9:54 am
 mboy
Painted lines in the wet...
There's got to be a better way of denoting a cycle track than by marking it with something that becomes lethal to cyclists once it becomes wet!
Posted : 29/12/2015 9:58 am
^ +100
Posted : 29/12/2015 10:01 am
'North shore' when it hasn't been ridden for ages and it develops a nice slippery layer of moss and algae.
Posted : 29/12/2015 10:03 am
There's a steep track carved into thick slate bedrock just northwest of Liverton on the way to Haytor..
Impossible to walk up in the wet but quite fun to try to ride down in a bruisey kamikaze concussion kind of way
Posted : 29/12/2015 10:06 am
damp paving slabs with leaves on them, damp wooden planks with no chicken wire, basically anything damp.
Posted : 29/12/2015 10:07 am
Haha, I'm thinking of Dalby now.
I was gonna say Aston Hill in the wet.
Posted : 29/12/2015 10:08 am
I'd say a set of stairs 😆
Posted : 29/12/2015 10:11 am
Wet canal towpath bricks around Birmingham, especially ones that form a bridge over canals or turn a corner
Posted : 29/12/2015 10:13 am
Lee Quarry, by the sound of things.
Posted : 29/12/2015 10:14 am
Aston Hill
Pretty much all of it unless it's bone dry. Slightest bit of damp and it's got about as much grip as a distracted toddler holding an ice cream cone
Posted : 29/12/2015 10:21 am
South Downs
Run off channels in chalk - your bike heads towards them and you head to A&E !
Posted : 29/12/2015 10:37 am
There's a wooden bridge in Chapel you go over when heading towards the tramway trail to Buxworth. In the dry it's fine, add the tiniest bit of moisture and it's like finely polished ice with a layer of teflon just to make sure and it's always the front wheel that goes first.....
Posted : 29/12/2015 10:39 am
+1 canal side stonework, bloody lethal
Posted : 29/12/2015 10:47 am
Anything up to and including anti slip coverings.....if using cheap non bc compound continentals.
Posted : 29/12/2015 11:00 am
northshore but made out of beds of nails. Am I doing this right?
Posted : 29/12/2015 11:03 am
Wet marble while on a road bike. Cycling past a shopping centre I ventured too close to the main doors and went down like a crash test dummy.
Posted : 29/12/2015 11:04 am
The cobbles that they hold the Bullring market on in Birmingham on a rainy day after the market's gone but before they scrub all the grease and fat off them.
Came flying through there on the way to Digeth, hit the grease, slid for a good 15 feet and wedged myself under the side of one of the bus stops on Upper Dean Street, much to the surprise of the dozen or so people standing in it.
My attempts to hobble off as if nothing had happened despite the blood and shredded jeans were less than convincing.
Posted : 29/12/2015 11:07 am
+1 more for wet chalk. The second half of day two on a two day SDW trip was haunted by wet chalk. You either have to have incredible skill levels and loads of luck, or you've got to slow right down.
Posted : 29/12/2015 11:10 am
Really polished white lines. Years ago at a Surrey League road race I pulled out of a group to go round and hit the white line. It was hosing down and the bike went from straight under me. I skidded along on my arse attached to the bike (I sort of stared at my mate in the bunch), at the same speed as the bunch, went across the road and into a big ditch filled with water. Ended up in about two feet of water with the bike still attached. Fortunately a following car had seen it and stopped to help. They pulled me out with nothing more than a graze. Good job there wasn't a car coming in the opposite direction!!
Posted : 29/12/2015 11:11 am
Dry, dusty trails with a build-up of fine gravel....
Posted : 29/12/2015 11:14 am
A damp Whinlatter. Fine in the dry, grippy as you like in the wet- more slippy than an eel covered in KY jelly when a bit damp.
Posted : 29/12/2015 11:16 am
Having never used Barons before (in any guise) was I batting at a slippy wicket from the off? No avoiding having to use tarmac etc to get to trails and I do sometimes like to dick around trially-style in the urbans innit. Lose some pressure? (those walls look thin tho ...). Bin them?
Posted : 29/12/2015 11:17 am
A thin, brittle surface of waspish arrogance hiding layer upon layer of bitterness and self loathing?
Posted : 29/12/2015 11:24 am
Another +1 for brick Birmingham canal towpaths. Fallen off 3 times in the last 5 months. Have considered starting a 'Technique or Tires?' thread to try to get to the bottom of the reasons for my crashes. Glad I can now definitely say its not down to my lack of ability! Maxxis Ardent's BTW.
Posted : 29/12/2015 11:28 am
Fords. The concrete laid under a stream things.
Posted : 29/12/2015 12:06 pm
Italian or Spanish tarmac after a gentle summer rain.
Posted : 29/12/2015 12:24 pm
The northshore / boardwalk at Laggan Wolftrax, now gone, may it burn in peace.
No chicken wire, no grip paint, always damp, always covered in algae / slime. Anything but riding in a straight line at a constant speed had you sliding off hoping not to plant yourself in a tree trunk before you hit the deck
Posted : 29/12/2015 12:38 pm
My sodding decking when it's wet. Alternatively the sleepers laid across the various ditches around Esher woods.
Posted : 29/12/2015 12:49 pm
a carpet of fresh fallen dry autumn leaves over a wet wooden footbridge. It helps if the leaves are bathed in a pool of sunlight piercing a still green early autumn woodland canopy - that way you can thinking 'isn't that lovely' just as you ride across what might as well be ball bearings.
Posted : 29/12/2015 12:50 pm
Tramlines out side my shop when it's wet dam things have almost killed me a few times over the last five years
Posted : 29/12/2015 1:12 pm
Wet cardboard box sent me flying off on my commute last week. I fell in to the road causing a driver to slam the brakes on. Could've been nasty.
Posted : 29/12/2015 1:24 pm
Dry Croatian tarmac, had some fun driving round there!
But back on topic green chalk is the nastiest thing ever to ride a bike on
Posted : 29/12/2015 1:31 pm
Cattle grids can be challenging, especially the round-bar version. We (tandem) had a memorable off when attempting a gentle turn while riding over one at speed. Took me a while to earn forgiveness for that one! Dead straight is the rule nowadays.
As for natural surfaces, loess makes for a very slippery surface when damp, a bit like clay. I thought wet limestone was bad when I first moved to the dales but getting used to it now.
Posted : 29/12/2015 1:58 pm
I had a good one at the bottom of the west side of Hardknott pass (coming up), it was pi**ing it down, pretty stupid weather to be riding in to be honest, and the rear wheel slipped on the metal, sending me sideways and down. I instinctively stuck a foot out to stop myself, which got stuck in the grid. Luckily I fell in the direction that meant my body weight bent my leg the right way, not the other way which would have been pretty grim. I ended up completely stuck underneath the bike, and had to wait, lying trapped on the floor, until some other cyclists came along and pulled me out.
Posted : 29/12/2015 2:21 pm
Cheviot sheep dung on a wet wooden bridge.
Posted : 29/12/2015 2:23 pm
Just this lunch time on my road bike. Took a cycle path alongside some fields which the farmer obviously also uses. Thin layer of cowshit, water from the fog and a steep slope means no traction. Narrowly avoided a balls/toptube collision but had to walk up the last couple of hundred metres in road shoes as I couldn't get going.
My favourite/least favourite MTB trail though is the XC at Aston Hill, never ever been anywhere as consistently slippery after a single drop of rain. That said, doesn't get much worse in a torrential downpour than it is in a light shower.
Posted : 29/12/2015 2:29 pm
The green slime covered rocks on the bottom of the stream above Lauder...
Posted : 29/12/2015 2:32 pm
Wet manhole covers can be a little slidey had a few close calls but luckily managed to wtay upright.
A molten lava covered BMX track would be pretty hazardous
Posted : 29/12/2015 3:18 pm
cannondaleking - Member
Sheffield? Doesn't even need to be wet and the tracks here are catching people out all the time. Often people trying to cross them at the wrong angle and getting wheels stuck
Posted : 29/12/2015 6:04 pm
Frosty roots (preferably off-camber).
other than ice
Possibly invalid.
Posted : 29/12/2015 6:37 pm
I crashed my motorbike once on a massive puddle of what I swear was ky jelly.
Failing that, it's whatever that mad algae stuff is that's growing on some of the rocks at kirroughtree. Smells awful too when you fall off on it and get it smeared on you.
Posted : 29/12/2015 8:35 pm
Aston in the wet.
Have ridden lots of places in the wet. That place is just nuts. Loads of fun but nuts
Posted : 29/12/2015 8:43 pm
I have three offerings:
Another for anywhere near astonhill or wendover, green slime on chalk or wet leaves on chalk. Your going down.
Crossing at Fenny Stratford over canal. Engineering bricks in the wet just when you turn right after crossing the swing bridge. Hurt bad and cost me a XO rear mech.
Mini roundabout up the road from me. On exit of a garage, diesel spill in the wet, turned right, first thing to hit the Tarmac was the side of my helmet, learned the value of helmets that day.
Things like this always remind me if taking my test 20yrs ago. The instructor asked us what you do when you hit ice on a motorbike. The answer. fall off.
Posted : 29/12/2015 9:02 pm
That steep slabbed descent between Scammonden and Rishworth in the Winter. Wheels slipping all over the place over those wet slabs. Don't know how your supposed to ride this in Winter.
Posted : 29/12/2015 9:19 pm
